Question about Sewing Machines
Brother super ace 2 how do i get the right tension on the top - its far too tight
bargainbox
  • 1388 Answers
SOURCE: I can't get my neetle tensions tight enough on my brother overlock machine
First thing is to make sure there is no lint etc caught in the tension unit, even a small amount can reduce tension considerably.
If that doesn't solve the problem, we need you to give more detail of the machine, as there are a couple of different tension units which require different methods, 'over the top' or 'around a knob' ........which of these two is most like your machine ?
If you want any more help with this, post back to here, or just drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 19, 2008
  • 26 Answers
SOURCE: bottom tension to tight
There's hardly any way to significantly adjust the bottom, or bobbin tension. There's just a small, flat spring attached to the side of the bobbin case, under which the thread runs. There's adjustment there. You need to adjust the top thread tension via the small thumbscrew that's against the plates on the top thread tension discs. Increase or decrease tension there until top and bottom threads are equally centered between layers of material.
You can adjust presser foot tension with the knurled nut at the top of the machine. I never had the kind of problem you mention though. I set my machine at about 6 stitches per inch or a little more (max is 5, recommended), and presser foot tension is only heavy enough to pull a single layer of material through.
Hope this helps.
Posted on Jul 13, 2009
SOURCE: My brother sewing machine is new and I've checked
Yes. Open the bobbin and u will see a screw pressing down a metal sheet, which is actually a spring.
This is meant for adjusting the top tension. Loosen this screw by quarter or half a turn and see if it is giving the desired result. You may have to try a few settings before you arrive at the even top and bottom tensions when your thread tension adjustment scale is midway position.
Please note that you adjust the thread tension on the machine to adjust the bottom tension(not the top) .
Please let me know if this solved the problem.
Posted on Oct 17, 2009
  • 96 Answers
SOURCE: suddenly, the tension is not right. have tried
there should be a dial on the front with numbers on it normal tension would be a 3 on the dial for light or medium fabric like cottons or light denim. Also the top of the machine on the left over the needle should have a round post that is spring loaded it affects tension to the feed dog if you push it down the tension will be tight, release it some by the small circular piece around the post and it will loosen
Posted on Dec 13, 2009
  • 3 Answers
SOURCE: How do I adjust tension top thread too tight bottom
The bottom tension is too loose. If your bobbin is in a case there is a little screw on the side that will tighten the plates and increase the tension. Test your thread coming out of the case as you slowly make adjustments to the screw. A slight bit of resistance is what you want. If your sewing still puckers you may have to loosen the tension on the top. Sew on a scrap and go toward the smaller numbers to loosen the top tension until the stitches meet between the two layers of fabric.
Posted on Dec 21, 2009
Tension on brother se1800 sewing machine isn't working right. Top thread appears on back of fabric, So far I've checked threading top and bobbin, cleaned race.
When threading the top thread, ALWAYS RAISE the presser foot so the thread will seat properly in the tensioner.
Then adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sep 08, 2017 | Brother Sewing Machines
I dont seem to be able to get the tension right
does it seem tight to just pull it thru or only when sewing
Jan 30, 2015 | Brother Sewing Machines
Tension on bc1700 super bike will not adjust
Just start over threading, that's usually the problem.
Jul 07, 2014 | Brother XL-5130 Mechanical Sewing Machine
Bobbin tension too loose
You don't give us the make and model of your machine.... so it's hard to give you decent specific advice. Secondly your question isn't making sense. If you are getting loops on the bottom your top tension isn't right(too loose) if your loops are on top your top tension isn't right.(too tight) The only time you would mess with bobbin tension is when you change thread weights significantly. Like from 40 weight to 92 weight or visa versa.
Look at your bobbin case, bobbin carrier, shuttle/carrier..... there is a spring (it's a flat piece of metal) on the spring is a small screw. Use a small screw driver and tighten the spring 1/4 turn. Loosen your top tension a couple turns. (remember right to tight, left to loose)
Mar 19, 2013 | Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
Brother LS-2125 - stitches forming loops on the right side as a sew
acing you has loops on it then it is the bobbin tension which is incorrect or the bobbin has been threaded wrongly. A good way to test tension is using contrasting colours top and bottom. Rethread your machine and tighten up the bobbin tension screw if needed.
Jun 15, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Brother Super Galaxie
Does it pucker when you are embroidering or just sewing in general? If its puckering when your embroidering it could be a few things. 1. no stabilizer 2. the fabric stretched in the hoop too tight. 3. check you tension
Oct 23, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
369 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
