Question about Sony VAIO PCGFRV33 PC Notebook
Where can i get a genuine battery n @ how much
Heat sink becomes very very hot after a few hours,cannot handle the pc on my lap,help
  • 22 Answers
The heatsink is probably clogged with dust/lint/hair.  You can get an air can and blow it through(temp fix) or have someone take it apart to clean it.
Posted on Feb 01, 2009
  • bsayas Feb 01, 2009
    Also check your battery against a sony battery recall list.  Do a google search.
Over heating and heatsink
Unless you are using something like speedfan from www.almico.com it is impossible to tell if something is really too hot. There have been reports of low end laptops that dont have metal frames overheating.
Dec 17, 2013 | Gateway MX6448 Notebook
My laptop is geting automatically close after running for long hour
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 05, 2013 | Acer Aspire 5742 Notebook
My acer laptop is in on state only for about 1 hour.It gets shutted down then.What can be the reason.Do I have to change the battery or motherboard?
Dec 29, 2012 | Computers & Internet
Nokia battery on internet becomes too hot
Using Internet on mobile continuously makes your battery box hot and also discharge your battery quickly. You should not use non-stopping streaming on your phone otherwise it will create some serious problem with your mobile. If you will use youtube application more than 2 hours on your mobile, your battery will get heat up, You have to change your battery and put new Nokia genuine battery. Contact your manufacture service center for original battery.
Nov 16, 2011 | Nokia Cell Phones
I have a Toshiba Satelite A135-S4546. The problem is that has been shuting down within a few minutes after starting without aparent reason. Battery normally last about an hour to hour fifteen minutes.
More than likely the heat sink is covered with lint and the laptop is over heating. You may be able to find a service manual on the Internet that shows the process of opening the laptop up and cleaning off the heat sinks. Some laptops require most of the laptop being disassembled to get to the heat sink so it may be a good idea to bring the laptop to a service center to be serviced.
Jan 26, 2011 | Computers & Internet
My daughters Acer 5536 overheats and turns itself off after a couple of hours of non stop use. Is it a fan issue or a common known problem and do you have a fix ? Thx
Remove the fan with heat sink - underneath is the CPU. Remove and re-apply the silicon compound between the CPU and heat sink. After time, the compound becomes dry and the heat absorption deteriorates. The purpose of it is to efficiently transfer the heat to the heat sink radiator to keep it cool - if the CPU reaches the maximum temperature threshold, it will shut down.
Jan 13, 2011 | Acer Aspire 5500 5570-2609 Laptop
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
Bathtub single handle faucet had not been used for a few months. Now when you rotate to hot water posiiton, there is no flow. Cold is normal. Hot water works fine at nearby sink & otherwise. Did an...
yes, and hopefully piece's of the cartridge's rubber have not come off and lodged in the water port's.have had this problem quite a few time's.remove your cart' and while it's out, run water to flush out the valve body.shine some light in body before re-assembly.
Dec 23, 2009 | Moen & One Handle Tub & Shower Faucet
No battery backup
then dont charge the battery too long and charge for daily one hour. and the battery may be damaged that so you get the heat problem
Sep 21, 2009 | Nokia E51 Cellular Phone
GPU heat sink standoffs came off
to do this i use my aoyue hot air gun and, a lot of flux however; there is an eaiser way: get some two part epoxy glue mix it properly and, it should hold quite well or, use clear silicone automobile adhesive sealant by permatex (you can get it at an autoparts store) wait 24 hours before you handle the motherboard i prefer the permatex
Apr 28, 2009 | Dell Inspiron 2200 Notebook
Sony VAIO PCGFRV33 PC Notebook Logo
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
