Question about Whirlpool GHW9100L Front Load Washer
Not spinning properly
When I did a load of wash, started spinning, heard a lot of banging, took clothes out of washer and found long stripes of white plastic. Looked inside of the rubber liner and found that the basket/drum has been warn off, lots of pieaces of it everywere. do you know were I can find a replacement of this piece? and what is this piece called.
  • 188 Answers
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
Posted on Feb 17, 2009
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
MY SON LOADED A LARGE AMOUNT OF CLOTH INTO THE WASHER AND WHEN THE SPIN CYCLE CAME ON THE WASHER STARTED MAKING A HORRIBLE BANGING NOISE. it does not look like the springs are broken but the washer seems...
I'm suprised the unit was not able to spread a large load around to balance the drum. Maybe some item bunched up and made one side heavy. For a front loader, a proper load is just about all you can cram in there dry. You'll notice when the clothes get wet, they take less space, and when they are spun, there should be lots of room in the middle.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Banging while spinning and disintegrating gasket
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Jan 02, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
289 people viewed this question
Dan Webster
Dan Webster
prem mathew
