Question about Estate TAWX700JQ Top Load Washer
Leak from pipe/wahing machine drain hose
Where the drain hose goes into the plumbing pipe next to the washing machine, water starts coming out out the top of the pipe when the machine is running. The black drain hose hangs down into the white pipe.
We have tried snaking it from inside and from the roof with no luck. any suggestions?
  • Anonymous Mar 22, 2014
    NEW LG top load washing machine drain hose is not long enough to reach stand pipe for draining wash water.
    Genius:
  • 2,920 Answers
Try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
Posted on Feb 01, 2009
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
Whirlpool AWM1019 wahing machine - what does AH code mean on display. Will do all the right things but wont move on ie wash and drain but then wont rinse. On start of any programme starts to fill then AH...
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Jan 23, 2011 | Whirlpool Washing Machines
Leak at back of machine
A leak at the back of a washing machine can come from several sources.
It requires a good investigation.
Here are some of the first area to look at that are on the outside of the machine
1 Hot and Cold Fill Hoses may not be tight enough. So water can drip down the hose, or back of machine onto the floor
2 Drain Hose-Usually about an inch or so in diameter. Hose in new machines should not leak itself, but if it is not mounted or attached well enough into the drainage plumbing mounted on the wall (The box with the Hot and Cold Water Shut-offs, it will leak or splash water onto the floor during the drain cycle.
3 Damaged plumbing in the wall can seep under the wall and end up under the washer. This is very rare, but I have seen it.
4 There is a filter mounted behind a panel on the lower back side of the machine. It is possible a leak is occurring from that area. Take off the cover and see.
If the above don't handle it, the next step is for what is not easy to detect. Leaks inside the machine. You will need to go into it and LOOK with your eyes and a good flashlight.
Hope this helps,
Best, Mark
Dec 31, 2010 | Hotpoint WMA54 Front Load Washer
Automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Feb 01, 2009 | Washing Machines
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Drain and vent
vent pipe in the house?sounds like a plumbing issue in the house. unless your drain hose is to far down the drain pipe.
Apr 14, 2008 | Whirlpool LSR5132PQ Top Load Washer
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Estate TAWX700JQ Top Load Washer Logo
262 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
