Question about Hotpoint 24 in. HDA3740G Built-in Dishwasher
Hotpoint Dishwasher that leaks from bottom of door.
I have tried everything. The dishwasher is 4 years old. It leaks really badly from the bottom of the door. I have taken it apart thinking that maybe a seal was bad. Couldn't seem to see anything wrong. Any ideas?
  • Hotpoint Master
  • 528 Answers
The spray arm not spining and shut water on the door all the time or the hole in the spray arm is clug
Posted on Jan 01, 2010
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Dishwasher is leaking from under the door
the lower door seals may be damaged or contaminated with old food debris. also check the "n" seal around the door are clean.
Mar 18, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher door leak
at the bottom of the door is going to be the door seal starting to go bad. replace the seal
Nov 24, 2008 | Dishwashers
DISHWASHER NOISE
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Jun 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Sep 27, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint 24 in. HDA3740G Built-in Dishwasher Logo
353 people viewed this question
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
bosch5
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
