Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi WT-46809 Powers Off; Code 2-2
My Mitsu 46809 powers on, the off in abot 2 seconds. Error code is 2-2. Fuses FA904 (125V, 5A-- 24V supply?), and FA905 (125V, 5A-- neg 24V supply) are open. These are on the middle board with the convergence ICs, etc.
I've got the board out now. I replaced the convergence IC's back in July 2007, but that time there were no blown fuses. Is this the same problem, or am I looking at a new dog here?
I'm a 30 year electronics tech (Air Force retired), with full equipment. Any tech advice would be greatly appreciated. I've got a lot more technical ability than I've got money- ha! If I can save this gal one more time, I'd really appreciate it.
Thanks so much!!!
  • Anonymous Feb 03, 2009
    Same problem, TV tech told me it would cost around $200 to repair...Not bad considering my buddy gave me the TV...
    Problem Solver:
  • 5 Answers
The 2 fuses you mentioned are associated with the convergence IC. If they are open then the convergence IC is either bad or you have a "cold" solder joint on the IC.
Posted on Feb 20, 2009
What component makes the loud click when you power on certain electronic devices?
the click is the relay which clicks when the set is powered on or off. Your model should store an error code when it shutsdown or wont start up. Have you tried accessing the self diagnosis feature to retreve the error code through the power indicators two digit blink sequence? If so whats the blink code your receiving?
Apr 05, 2013 | Mitsubishi WT-46809 46" Rear Projection...
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809 will not stay on
Good Day, dimen;
This looks great. Check this out;
SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Jun 22, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Television automatically turns off after a couple seconds
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Jun 09, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Turns on with Power light then turns off
Jun 07, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Error code 2-2
error code 22 means short to ground. for a start check your power supply to see if anything is shorted to the ground.
Oct 14, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
311 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
