Question about Dryers
Stopped working all together
Dryer would stop running in the middle of a cycle, heat would still be on(and would get hot), would push nob to restart it, sometimes it would restart and sometimes it would not. Now it does not run at all.
  • 547 Answers
Replace controls
Posted on Feb 11, 2009
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
Gas dryer 12690. When stopping dryer in the
When the dryer stops and you try to restart it do you hear a buzzing sound? If you do then you have a overheated drum motor. Full of lint or bad motor bearings. If bad motor bearings only solution is to replace the motor.
Mar 29, 2010 | Kenmore Dryers
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
Dryer will stopping running in the middle of a
Sounds like you have a problem with the thermostats that govern the heat, you may have to replace one or more of them.
Look in the air tube from the blower that is where the thermostats are normally located.
Sep 25, 2009 | Maytag Dryers
I own a Maytag Dryer that has stopped working properly: Model LER6620PQ0 Serial MS3647251 Type DWJR-ELE-2406028-FM54 On all cycles, the timer moves until it is ready to stop. At that position, it...
Dear Paireyes,
Things that can stop electric dryer from heating are as listed: house fuse or breaker, heating element, burnt wire, thermostat, thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug
To check various points here are the simple tips:
  1. To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
  2. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
  3. To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
  4. To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Here is the link for the dryer and how to disassemble the dryer along with the images:
http://www.applianceaid.com/may-apart.html#common
Let me know if that helps. All the best :)
Regards,
Srinivas
Jun 23, 2009 | Hardware & Accessories
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
After water turns on, nothing else happens
If you are hearing a humm noise after it stops filling, your motor is locked up.
Jan 04, 2008 | Dishwashers
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
