Question about Intel D845WN (KD845WNPAK10) Motherboard
WHAT IS THE MAXIMUM RAM OF THIS MOTHERBOARD
I HAVE ONLY 375 RAM AND I WANT TO ADD MORE BECAUSE I WANT TO USE WINDOWS VISTA HOW MUCH MORE RAM WILL I ADD
  • 565 Answers
Maximum memory for your compuer is 3 (G)igabytes. Vista runs ok on 1G of memory, but much better with 2G.
To see if there are any other issues, run the Microsoft Vista upgrade advisor
http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx
Posted on Feb 01, 2009
    Brigadier General:
  • 5,158 Answers
• Three SDRAM DIMM sockets.
• Designed to support up to 3.0 GB of system memory
Robert
Please take a moment to rate this solution.. thanks
  • Roberta Smith
    Roberta Smith Feb 01, 2009
    you need at least 512 mb to run vista
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache.
Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.
If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
Jan 05, 2012 | ASUS GeForce Computers & Internet
Does ASUS P5GC-MX/1333 Motherboard supports DDR2 800mhz ram.?i'am havin 1gb ddr2 667mhz ram and i want to add 2gb 800mhz ram to it
Hello Tarun - No it doesn't. It would run OK but you would not gain any performance as the ram will only run at the same 667 MHz.
The limitation of RAM speed is dictated by the specs of the Intel 945 Chipset the motherboard is based on. But certainly add more ram, especially if your running Windows Vista or Windows 7 which both need at least two GB of RAM to perform well.
Happy upgrading and thanks for using Fix Ya.
Mikeywaf
Mar 21, 2011 | ASUS P5GC-MX/1333 Motherboard
What is the maximum amount of ram that it can the memory be upgraded to?
The manufacturer's web-site:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=VGNNS160DW
is totally non-helpful.
If you have the 32-bit version of Windows Vista, then the maximum supported by Vista is 3GB.
If you have the 64-bit version of Windows Vista, then the maximum supported could possibly be larger.
But, of course, the motherboard would have to support more than 2GB.
Best advice: take the computer to a computer-store, get them to install more DDR2 RAM, and see if the computer will recognize all of the RAM.
Jul 03, 2010 | Sony VAIO VGN-NS160D/W Notebook
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
I have 512 sd ram but i another 128,128 sd ram do included but its not working how can i solves this problem
The D815EEA2 motherboard only supports 512MB RAM maximum - I'm afraid there is no way to add more to it.
From Intel's description of the model:
Intel 815 Memory: Three 133MHz SDRAM DIMM sockets. Supports a maximum 512MB of 133MHz SDRAM
Aug 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Video card
There is no maximum video memory. When you add ram you add ram that can cap off at some point but is not called video memory. It is just computer memory. Sometimes your onboard video will share some of that memory. Older systems dont handle more then a gig 2-3 year old systems general no more then 2 gigs and really new systems can go up to 4 gigs of ram
Mar 19, 2009 | ASUS P4S533-MX Motherboard
Best Graphics Card, RAM for D101GGc
go for the nvidia geforce 8500, your board Support for up to 2 GB of system memory so no 4GB( too bad)
Jan 27, 2009 | Intel D101GGC Motherboard
How much ram is suitable for 2666mhz processor
1 gb is ok but if u put more ram is much better.
Jan 17, 2009 | Intel 845GE Motherboard
How much memory the motherboard ASUS INTEL 815E CUSL2-M SUPPORT?
no you couldnt, the max supported ram on the board you have is 512
Maximum 512MB PC133/PC100 non-ECC SDRAM
http://www.motherboard.cz/mb/asus/CUSL2-M.htm
Dec 10, 2008 | ASUS Intel 815E Chipset CUSL2-M...
Brand new gateway m-6846 vista 64bit
The maximum amount of memory that your system can use is actually limited in two ways — not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept.
For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used only by high-end users), your system will see (and utilize) only 3GB or 3.5GB.
Relax, there isn't a problem with the memory. Windows allows for 4GB of memory to be addressed, but this isn't 100 percent the same as having 4GB of physical memory.
What happens is that some of the addressable memory (regardless of how much you have physically installed) is reserved for use by page files or by some of the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc., so it's unavailable for use as normal main memory.
The amount of memory needed for these devices is calculated by your system at startup; if you haven't maxed out the memory in your system, it's invisible to you, and all your physical memory (the RAM that's installed) is available for use. However if you've maxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM.
The maximum memory limitation varies by operating system; for instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Memory maximums for current Microsoft® Windows OSs include:
  • Windows XP Home: 4GB
  • Windows XP Professional: 4GB
  • Windows XP 32-bit: 4GB
  • Windows XP 64-bit: 128GB
  • Windows Vista Home Basic: 4GB
  • Windows Vista Home Basic 64-bit: 8GB
  • Windows Vista Home Premium: 4GB
  • Windows Vista Home Premium 64-bit: 16GB
  • Windows Vista Ultimate: 4GB
  • Windows Vista Ultimate 64-bit: 128GB+
  • Windows Vista 32-bit: 4GB
  • Windows Vista 64-bit: 128GB+
May 23, 2008 | Computers & Internet
Intel D845WN (KD845WNPAK10) Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
