Question about LG 42LC2D 42 in. LCD HDTV
Picure and audio suddenly go away
Pic and audio suddenly go away, screen blacks out, audio goes away. Cannot make any adjustments, no menu or anything can be done. TV apparently will turn off and on but nothing shows or sounds.
Unplug and let sit for 30 minutes or so and it will turn on and everything seems to be working again, then, suddenly, no picture nor sound. Tried another input to TV with same result.
  • LG Master
  • 5,568 Answers
Since you have already tried a different source of signal, you can be sure that the TV's at fault.
The type of problem you're having is mostly caused by a failing or failed power supply. This may well be mounted on a separate board inside the housing. After removing all the cables attached including the AC cord, remove the rear housing and see if you can identify the power supply; this is not normally too hard, follow the AC input and the supply should be the first board to which it is connected.
If it has an identifiable part number on the board, you can call LG to see if they have an exchange or replacement price that makes sense to you. Boards will often have multiple part numbers; if you see one that clearly could be on a bare board, that may not be the right one. Look for one on a sticker or obviously printed but not as a part of the etching process. There is often also 'revision' numbers along with the basic part number. Both of those should be used to get the correct version for your set.
Posted on Feb 01, 2009
There is double vision at times, then it goes away.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking pic
*White looking pic
*Halos around objects
*Red/Orange looking pic
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 07, 2010 | Televison & Video
No Sound, Black Screen, 42" KDF-e42A10
If your tv is flashing 7 times. Disconect audio module. It is on top of power supply. Turn tv on you will have picture. Conect the audio outout from the rear. To the aux. input of a stereo. Where you night control audio level. Or get a new audio board. Its is very expensive get only the audio amp I. C. The audio. part. No. 1-866-539-11
May 25, 2009 | Sony KDF-E42A10 42 in. LCD Television
Black box on bottom of screen only when playing DVDs
Make sure the closed caption is in the off position
Feb 26, 2009 | JVC AV-56P575 56" Rear Projection...
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Haier Plasma Tv Screen went black
This model has several defective boards and eprom chip. There is an upgrade kit. I'll attach the kit part number and upgrade instructions. http://service.haieramerica.com/documents/SB-TV-0003.pdf
Feb 20, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Picture size
Assuming power supply voltages are correct,ie regulated sources,you will need access to the servicer menu via the service manual or CD ROM info for that make/model.(2)reset screen control adjust on IHVT (transformer).(3)solder any/all bad connects,esp.regulator pins. Practice visual acuity technique!!
Sep 25, 2007 | Toshiba 36A40 36" TV
Mitsubishi 55 in. WS-55315
Go into the menu and see if your closed captions are on and set to "TEXT". Setting the closed captions to "OFF" should solve your problem.
Jul 26, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
200 people viewed this question
Computer Repairing
Computer Repairing
