Question about Nokia 6682 Handheld
Media Net When trying to connect the icon at upper left keeps flashing and I get the "connecting via 'Media Net'" but no connection is made. It flashes until I cancel.
  • 560 Answers
SOURCE: phone blocked whilst trying to flash firmware
You need to bring your unit to cellphone technician. They have special cable for connecting dead units to a box then to computer and reload the firmware. the cable and box are very expensive and not advisable for 1 time use.
Posted on May 10, 2010
0 characters
1 Points
How to transfer LG cyon 2MP camera photos to computer
1. Connect your LG Cyon to your computer via it's USB cable.
2. Upon receiving a "USB Connected" notification atop the Notification bar, drag the bar down and select "USB Connected."
3. Now select the option corresponding to "Turn On USB Storage" or connect as "Mass Storage Device"
You should now see a new flash drive or storage device connected to your computer. Browse/Move/Copy/Delete files (including photos) as you would with any other flash drive or thumb stick.
Sep 25, 2011 | LG Cyon
Help with pre-owned iPAQ h5555
I have an IPAQ 5555 and although it's old it works pretty well. A few things to be aware of - you need to upgrade the ROM to the latest version. I don't have the links to the downloads but you should be able to find them on the HP site.
The problem that you will likely run into is Windows 7 and Activesync. I did everything via Activesync on Windwos XP - hooked up to my PC and installed software, sync'd appts and contacts etc... Activesync won't install on Windows 7 due to "incompatibilities"
I just installed "Windows Mobile Device Center" for Windows 7 and was able to get my device connected to my machine but syncing is not yet working.
As for WiFi access, from what I remember it's just a matter of turning on the networking via the Ipaq Wirelss app (icon is a little green square) and then turning on WLAN. That will hopefully cause two little left and right arrows to appear up in the top blue bar on the device's screen - the top left LED should also flash green to indicate that you're connected to your network. If the LED is flashing amber then your networking is on but your not connected to anything yet. If this is the case then the icon showing will likely be two arrows with an x. Touching this icon should open a small window called "Connectivity". On this window you can click on the "Settings" link, go to the "Advanced" Tab and rthen click on the "Networks" button at the bottom of the resulting screen.
You should now see a list of available networks - make sure your router is broadcasting Wireless G and not just N or you probably won't see it. If you do see your network's SSID then touch and hold the entry and select the "Conect" 'option on the resulting menu.
Starting out I would keep your wireless security turned off just to keep it simple. If you can connect this way then you can think about securinng your network. Once secured it's basically the same proceudre but you just have to enter your WEP key.
btw if installing some of the HP service packs etc.. for 5555 doesn't work using Windows 7 and the Mobile Device Center (it may .. I haven't tried) you may try loading Windows XP Mode on your Windows 7 box and then installing Activesync in the virtual environment and working in there just to get your device upgraded
Hope this helps. Good luck
Feb 19, 2010 | HP iPAQ H5555 Pocket PC
My palm centro will not turn on the red light just blinks and occationally it does come on
Hello abevagota25,
A flashing red indicator light (upper left-hand corner) occurs when the Centro is connecting to the the cell phone network. The light will continue to blink until it gets a strong enough signal to make a good connection. Try turning the phone on from different locations to see which one makes a good connection
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
Feb 02, 2010 | Palm Treo 500 Centro
Wabt to Sync an SPV M3100 on Win Mob 5 with Win
Download the Windows Mobile Device Center from vista site but make sure you pick the right version (i-e 32 bit version or 64 bit version) to check that do as follow;
Right Click -> My Computer -> Properties
Then look for "System Type" if it says "32-bit Operating System" then choose "32-bit version" else choose "64-bit version".
After installing the "Windows Mobile Device Center" connect your mobile with pc via usb cabel and it should connect.
If it doesn't connects on mobile open "ActiveSync" then choose "menu" then "options" and click the small icon of the pc and press "delete" repeat untill there is no icon left. After that reboot your mobile and connect to your pc and it should connect now.
If you have any other questions please feel free to contact...
Sep 23, 2009 | Orange SPV M3100 Smartphone
User manual of bluetooth headset H200
Press and hold down the button on the front of the bluetooth (has little phone symbol). Wait until it is blinking blue, means it's on. Keep it held down longer, it will be a constant blue light, no blinking. That is pairing mode. That is when you should search for the device via your phone and it will come up as H200. Pair, put in 0000 as your code. Should connect. Hold down the button on the bluetooth while on and it will blink red once and that means it's off. While connected to your cell it can answer your calls, hang up calls, up/down volume, ignore calls, and call the last person called. The pairing thing took a while for me to figure out, I have the manual and it doesn't say anything about waiting until it's a constant blue light. Make sure you keep holding it down until the blue light is on, NOT flashing, it will start flashing but keep it held down until it stops flashing and is on.
Hopes this helps!
Sep 20, 2008 | PDAs
Cannot connect to internet via wireless
my phone dont want to connect to intrnet
Jul 31, 2008 | i-mate K-jam Smartphone
Nokia 6682 Handheld Logo
14 people viewed this question
Top Nokia PDAs Experts
Are you a Nokia PDA Expert? Answer questions, earn points and help others
