Question about Janome Sewing Machines
Zigzag won't enlarge
My adjustments don't seem to want to increase the width of the zigzag. The length is fine, and does adjust from button hole to w-a-y stretched, but the width seems to stay only on very small stitches.
  • quiltedcactu Feb 01, 2009
    It is a mechanical machine. I'll open it up and see what I find.
  • quiltedcactu Feb 04, 2009
    After a little more tinkering, it seems to be related to the feed dogs mechanism. This button is VERY stiff. At one point I could get the feet in the up position, and got the stitch regulator to click in. It's working now, but ready for the serviceman I guess. Thanks for the help.
    New Friend:
  • 186 Answers
See if there is a twin needle lock out setting, if it is on it will cause this symptom. Otherwise there may be a bind in the needle pivot or linkage system to the needle bar from the cam or stepper motor (I don't know if this is a mechanical or electronic machine).
Posted on Feb 01, 2009
The zigzag stitch will adjust width but not length
If it's a mechanical Bernina, it could be some of the lever mechanics have seized from old, dry oil. You can try liquid Tri-Flow Synthetic Oil--a couple drops where metal rubs on metal to see if it loosens things up. Applying hot air from a handheld hairdryer will help speed it up. The other possible alternative is that something is no longer attached to the knob/lever.
If it is a computerized Bernina, you should probably take it for service.
Aug 04, 2016 | Bernina Sewing Machines
How to adjust the needle when using the zig zag mode
All machines are similar.
Push the zigzag control to begin: To control the zigzag appearance the width and length have to be changed.
Width: This is to control the width just as it says; wide.
Length: This is the length of a straight stitch. As it is made longer the length of the zigzag from one tip to the next tip will lengthen. If it is made shorter the tip to tip measurement will shorten.
This is easy to learn. Give it a try on old material.
May 19, 2015 | Baby Lock Sewing Machines
How to I adjust the feed dog when using the the zig zag feature?
1. The feed dog is adjusted by raising or lowering the length of stitches.
2. The other control that is of concern for zigzag stitches is the width control being raised or lowered.
May 19, 2015 | Sewing Machines
Can I sew on buttons?
Set the zig zag the width of the holes. Do you have a button foot looks kind of like a half moon
Apr 25, 2015 | Bernina Sewing Machines
How i can adjust the stitch ?
A zigzag can be adjusted by the width and length of the stitch. If you start with a straight stitch it is easy to see what the length of the stitch will be. The width is adjustable. By adjusting the two together you can have a large choice of quality stitches.
Feb 07, 2015 | Sewing Machines
Juki LZ 586 industrial zigzag
Most likely medium setting is best to set your machine for adjustment
Dec 06, 2013 | Sewing Machines
I need to know how to make a button hole, can't find manual.
Hi there, don't know your machine but you can do a plaiin buttonhole manually.
Set machine up for zigzag stitch, needle to left side, mark out the size you need with pins or marker pen. Start at the top and set for widest zigzag with 0 length for the top bar, cannot give sizes as don't know the button you are using, about 6 stitches, set stitch width to just over half the width of top bar and length to approx 0.5. Stitch down to bottom marker and again set up ffor the wide bar, do the same amount of stitches as the top, finish with needle down at the outside edge, turn work so that you will now stitch down the other side to meet the top bar, not forgetting to adjust stitch length and width again.
Hope this helps
Ellie
Jan 09, 2011 | Necchi 3537 Mechanical Sewing Machine
Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Jul 27, 2008 | Necchi 3537 Mechanical Sewing Machine
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
