Question about Coleman Electrical Supplies
No ac seems to be under some load when running empty
Gen is easy to turn manully,not jamming. nothing rubbing any place ,brushes.etc. seem to be okay. no hint of burnt wires on stator or anywhere else. is there anything else i can check ex. fields with ohmeter ? thanks.
    Problem Solver:
  • 10 Answers
I'm not for sure what your asking, but i'll try. I believe your saying you have no a/c out. In the middle of your end plate on the generator there is a little removable cover. Remove it and it will expose your brush connections. Ohm across those terminals. Your meter should read around 10 ohms give or take a little I don't have a chart in front of me. If you get OL(no resistance) your circuit is open either at your brushes or your rotor. If you get a high reading in ohms 80ohm or 50k your problem is the brushes dirty worn out. If that's ok check the capacitor test to its rated farad. Then check the two diodes in the end plate. remember to swap you meter leads around to check both the resistance and gate. The only thing left is the stator and there should be almost no resistance through each winding and not correction to ground. Remember to isolate each circuit as you test or you'll get fails readings. I would also check resistance though every wire and connection. Also if you have replaced parts or have not used the unit in a while once it is back together take a 9 volt battery and touch it to the brush terminals with the correct polarity just for a second to bring back residual magnetism. I believe the out side slip ring is negative. If it dosn't try it the other way it will not hurt anything.
Posted on Feb 03, 2009
Drill keeps stopping put new brushes in if I tap chuck end it starts up
There is one or more defect collector in the ancre the commutator place a resistance measure on the both brushes on the ancre and turn slowly the chuck then there is a place that wil measure nothing or great difference in resist , replace a new ancre (if its a FESTOOL < DEWALT< BOSCH FEIN or MILWAUKEE or other quality machine, and maybe also if the stator is colored dark and if measured the both poles are not in balance then also replace the coil stator (field magnet) , working with the tool at this moment made a wrong sound noise. and its eating the brushes very fast again. Have you used the drill on a generator mostly there is a problem with to high voltage , if it was then you see nothing looked like damaged only with a measure , but if it was overloaded you see different colored collectors o the ancre .
Apr 03, 2015 | Drills
The brushes on my Panasonic upright vacuum cleaner are not going around but the belt is
Sounds like one of two things possible. The belt may have stretched and is no longer applying enough tension on the brush or the brush is jammed and unable to turn.
Feb 11, 2015 | Panasonic Vacuums
Hoover se147 washing machine, wont spin at all , it will fill and drain. Have checked pressure switch and appears okay. Have also had circuit board out and that seems okay.
Have you checked the carbon brushes within the motor, chances are they are worn. you will need to remove your motor to get to the 2 carbon brushes.these will be in a plastic casing, held in place by 2 screws. There is just 1 wire going to each brush. When brush is removed, the carbon should be at least 20mm long. If not replace with new
Aug 13, 2011 | Washing Machines
LE code comes on-I followed tip of turning wm off and retrying 1/2 hr later. Ran spin only to drain h2o, then ran rinse & spin cycle only-h2o would fill, unit won't spin-code LE comes on. Any hints? ...
Had the same problem myself. The LE code is a motor fault and I found the rotor magnets and stator coils to have areas with thick layers of oxidation. I removed both and cleaned with a wire brush but with the stator it should be the top end that the rotor magnets face so don't take the wire brush to the copper windings. Apparently at some point my washer was leaking at the water supply connections and although this was a very small leak overtime it adds up and it happens to drip directly above the rotor. I sealed the open edges of the water supply box with electrical tape to prevent water from dripping in just in case it ever leaks again.
Sep 26, 2010 | LG WM2016C
Checked capacitor, diodes and circuit breakers and all check out ok. Still no output voltage. Excited with 12 volts across brushes. Still no output voltage. Took the head off and check field windings which...
Make sure it is not the brush set.
There must be continuity from one slip ring to another.
If not, but rotor doesn't look burnt - check points where rotor wire is soldered to slip rings, or clear contact point on each side of wire and check continuity there, past slip rings and brushes. Big chance that wire came loose from slip ring.
Had such problem on my Champiion 3500
evern if burnt - rotor is easy to rewind at home, unlike stator.
Unless your model is Inverter type - there is AVR module.
But, unless your rotor has continuity - don't bother going further.
Jan 13, 2010 | Coleman Powermate Powermate 5000W...
5000w gen. no powe out put
when engine runs but no power is produced ...there are three things you need to check:
1- brushes may be shattered.(open the generating unit cover(from the stator and rotor side) and you'll find it..if it is shattered..then replace it.
2- breaker...to test this disfunction...connect the two wires(the one going to it and the one coming out of it) together and try again...if it generated power..then the breaker is out of order...either replace it...or keep it connected directly (DON'T leave any naked wires)
3- AVR open the generatng unit cove again.you'll find the AVR (screwed to the rotor holder) here is a picture of an AVR:93c8b52.jpg if it is burnt out...replace it..
IF you tried the 3 things i wrote and none of them worked, then you have a problem with the stator or the rotor...but that is very rare to happen...it's probably one of the three///..
Dec 17, 2008 | Coleman Powermate Powermate 5000W...
Coleman generator model PM0555523 only have 1.9volts output
I couldn't find anywhere to get a wiring diagram for any models of Coleman Powermate, they are out of business. Not to worry, I've repaired LOTs of generators so I'll use this answer as a general one for how to troubleshoot "no output" problems and refer to it in other answers. My apologies for the stuff that doesn't apply to your situation.
The first thing to know is that portable generators have to be run with some kind of load about once every 3 months in order to keep working. So if you've stored your generator in the shed for a couple of years it may just need to be flashed. If that's not the case the rest of this procedure applies.
I'll write one of these about how to flash a generator when someone asks for it on FIxYa :-)
If the engine runs more or less as it always did, we can eliminate it as a problem. If it ran more slowly than it is supposed to it would be a problem. If it ran but sounded like it was loaded even with nothing plugged in that would be a different problem. It should run at just over 3600 rpm just like a lawn mower.
Looking at the back end of the generator you'll find a plastic squareish cover held in place by 4 long bolts that run all the way thru the generator, this is the endbell cover. Get out a 7/16 box end wrench and a socket and remove the 4 bolts, there will sometimes be a ground wire and lug on one of them that you just move out of the way. Gently pull the cover off if it doesn't fall right off the end of the generator, there may be wires connected from the endbell cover to the windings of the generator. There may also be a set of graphite brushes sticking out of the endbell cover. Look at the wires that come out of the part of the generator that doesn't move (stator), there will be at least 2 and most likely 4 of them that are larger and go off to the outlets of the generator. Look for obviously broken wires. You can check these power windings of the generator with an ohm meter, on the 4 wire models you should find that there are 2 sets of 2 wires that measure less than an ohm with no connection between them, none of the stator winding wires should be connected to the generator frame.
Looking at the end of the generator you will now see one of 3 basic ways of building a generator;
a) nothing at all connected to the rotor part of the generator, and a capacitor with 2 wires that go to a winding on the stationary part of the generator. This is a brushless generator.
b) a flat plastic plate connected to the shaft of the rotor with 2 metal rings in the surface of it. There will be 2 brushes in the endbell cover under a little PC board, and 2 wires will run to a winding on the stator.
c) a brush holder assembly that has 2 brushes riding perpendicular to the rotor shaft on 2 metal slip rings. There will be wires connected to this assembly, on some models these wires go directly to the windings on the stator, on others they connect to a voltage regulator module.
If this is a brushless model, check the capacitor first. You can visually inspect it for cracks, obvious damage, broken wires and so on but the only definitive test is to get a meter and measure it. The value in microfarads will be written on the side of the capacitor somewhere.
If the capacitor was good, look at the diodes and movs located on the rotor itself. Usually these are tucked into 2 little slots in the plastic frame that the rotor winding wires wrap around. If you don't see any visual damage like broken wires, burned parts, etc. You'll have to unsolder one end of each of the diodes to test them. Just unsolder one end and unwind the wires for the 3 parts that connect together (winding, diode, and the mov behind it), this keeps us from getting the diodes back in the wrong direction later. Use the diode function of a DMM to test the diodes, check the rotor windings with an ohm meter (should be tens of ohms from the disconnected wire to the other end of that diode) and check that the mov(s) aren't shorted.
If all of that stuff checked good, put it all back together and try flashing the generator.
Generators with brushes:
On both types of brush arrangements above, examine the brushes themselves first. They have to be long enough to press against the slip rings. Also look closely at the slip rings themselves, under normal use they'll become dark and a little worn but too much junk on them is enough to keep the generator from making its rated power. Clean them with a bit of fine emery if they are dirty and the using an ohm meter measure from one slip ring to the other, you should get something between 10 and 100 ohms depending on exactly what pawer rating your generator has. The main things to look for are that the rotor winding you're measuring is not an open circuit and isn't a dead short. Also measure between either slip ring and the shaft or the rotor, you should get an open circuit.
On those models with a brush holder assembly you'll need to remove it to do the above checks. Mark it first with a Sharpie or other pen so that you'll be able to get it back in the same direction it came out, then using a 9/32 socket or nut driver take the bolt out of it. Be careful as this is not a good bolt to break off. On all brush assemblies look for evidence of melting of the plastic housing, when this happens the brushes can't make proper contact with the slip rings.
If the rotor checked good, and the brushes looked good, we need ot check out the part that supplies the voltage to the brushes. On the models with a flat plate commutator ( case b above), there will be 2 (usually yellow) wires that come from the stator and go either to a plug on a pc board mounted in the endbell cover, go to a metal plate with 2 diodes mounted on it on these older models just disconnect the wires and check the diodes and the capacitor, check the stator winding too. On models with a pc board, unplug the wires from the board and check the stator winding. Next take out the 3 phillips screws that hold the board to the endbell and look for burnt or bad solder at the place where the socket pins go into the board. Other than visual inspection of the board there is not much on it that someone unfamiliar with electronic power supplies can test on it. Check for broken wires on the brushes themselves.
The only other thing to do on these flat plate models is to reassemble them, flash them, and see if that fixes the problem.
On models that have a brush holder assembly with just 2 wires going directly to the stator, mark and remove one of the wires on the brush holder then measure the resistance of the winding from the wire you removed to the other wire where it attaches to the brush holder. You should not see an open circuit, and this winding should have an open circuit to the generator frame (as in not shorted inside the stator). Resistance values of a few hundred to a couple of thousand ohms are normal for these windings. If all of that is good you may have a bad part on the brush holder assembly, like the pc boards above troubleshooting them is not for the untrained.
On those models with a voltage regulator module connected to the brush holder assembly, find the wires on the voltage regulator that go to the stator (usually a blue and red wire marked 4 and 6), and make the test described above. If that checks good remove one of the wires that go to the brushes and measure the resistance across the brushes, you should see a resistance that's almost the same value as when you measured across the slip rings earlier, if not the brushes are bad or misinstalled. As far as I know there is no way to repair the potted voltage regulator modules used in most small portable generators. If you've gotten to this point and a good visual inspection of the voltage regulator module hasn't convinced you it's burned of otherwise broken rate this answer and ask me directly for how to troubleshoot around the module they're expensive little buggers.
OK, if you've gotten this far you should have found something broken in the generator that you could replace, now you just have to figure out where to get a replacement part for your particular generator.
I know a little about that too but I'll insist on having to be asked.
If you got this far and found that you've got a broken rotor or stator my advice would be to go look for another generator if possible. It isn't hard to change out either of them really, but it does require skills that are best taught in person by someone who has done it before.
If you got this far and haven't found anything broken, you can ask me directly and I'll give you my best advice.
To ask questions of me directly you'll have to go to my profile and hit the "ask me" button I think.
Good troubleshooting,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
No suction
you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Electrical Supplies Logo
    78 people viewed this question
    Top Coleman Electrical Supplies Experts
    John Trevino
    Craig Butler
    Craig Butler
    Phil Walker
    Phil Walker
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
