Question about Hitachi 50FX30B 50" Rear Projection Television
Cannot program tv using bell satellite remote
Having problems using my bell satellite remote to turning on and off television 50FX30B . Have to use separate remotes. TV remote to control the on/off and volume. Bell remote to view the menu (channels we want to watch). Tried all codes in the Bell book to program, as well as Bell tech support. Negative results. CAN YOU HELP. Thanks
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Posted on Apr 01, 2009
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
I have a 27 inch symphonic crt tv. i have a bell satellite reciever hooked up to it with the renote programmed for the tv. i accidentally hit the mute button and now there is a 2 on each corner of the tv...
hi there, plugging and unplugging won't work that way. Pls try This:
1. look for the Program menu of your bell satellite unit
2. under menu you will see the settings there and try to reconfigure it or reset the current program.
3. scan for available channels and save it. i hope this will help you a little. Thank You.
Feb 07, 2011 | Televison & Video
I'm looking for the remote code for the PRIMA LC-20Y15 television in order to activate my remote control for my Bell Satellite system. Any ideas? Thanks
The remote codes are here.
I didnt see the Prima LC, but you can still problem with the instructions below.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Dec 21, 2010 | Televison & Video
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
Nov 26, 2010 | Televison & Video
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
Program bell remote to emerson tv What codes do I use to program my bell satellite remote to be able to tun off/on tv and to use the volume from one remote
Hi try this
Emerson 526, 534, 536, 541, 573, 590,
627, 636, 642, 648, 652, 654,
655, 657, 658, 659, 660, 661,
662, 665, 666, 667, 669, 670,
677, 679, 682, 692, 696, 699,
720
http://www.bell.ca/web/tv/en/all_regions/pdfs/deviceCodes.pdf
good luck please rate
Dec 18, 2009 | Bell Televison & Video
Big black box accross the screen in the middle of tv
Use the remote, find Closed Captioning and turn it off. It is in Text Mode which is not used in most areas.
Sep 05, 2009 | Televison & Video
Won't turn on
Resolder all poor connections,relay resolder it check Fuse903 and Non-Poliarized capacitor 4.7uf 50v C730
Oct 12, 2008 | Hitachi 50FX30B 50" Rear Projection...
I have an RCA universal remote and I need a code for a Bell ExpressVu satellite in order to use the remote for both my TV and Satellite.
004 was the only code I could find for Bell but i do not think it will work. Therefore, i recommend the following:
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 26, 2008 | Televison & Video
Televison & Video Logo
1,516 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
