Question about Kenmore 44102 Front Load Washer
Kenmore 44102301 washer will not turn on
My 2 year old Kenmore washer will not turn on. I have checked the circuit breaker, power and water line. Does this maching have a fuse?
  • fixer444 Mar 01, 2009
    Check your washer plug, wires, there could be a fuse in plug. I had that problem. Check the power point with another appliance.
  • 15,935 Answers
No - no fuse. It appears your main controller board (timer) has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
Hello MrBig57,
Try unplugging the washing machine from the mains for about 15 minutes, turn off the circuit breaker to that socket. After 15 minutes, turn on the breaker, plug the machine back and see if it responds normally.
If that does not work, it could indicate a problem with the control panel or some other component that will require dismantling.
I recommend you get a professional to to do the job.
If you wish you can contact Maytag HERE.
Or call them using these numbers:
(866) 616-2601 U.S.
(800) 688-2002 Canada
Hope that helps!
Thank you for using FIXYA!
May 11, 2008 | Washing Machines
Www managemyhome com
If nothing clogged up the drain/pump system, then check the circuit breaker and then the power cord.
Aug 28, 2014 | Kenmore Washing Machines
Our whirlpool washing machine is 2 years old. It
Lid switch bad. Turn on and push down on lid switch with something
Aug 03, 2009 | Whirlpool WTW6400SW Top Load Washer
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Washer will not start/continue with cycle
check if the water pump is not blocked in any way preventing the water from emptying properly as the machine wont continue until the water sensor tell the machine that its ready for the next cycle the pump may not be doing its job preventing the next cycle to take place eric
Jan 15, 2018 | Kenmore 24872 Top Load Washer
Won't spin or agitate - will pump water water out
This is caused by either a bad door switch or a speed control unit. There is no way to test the door switch but it is the cheapest to replace. Try that first then the speed control. The door lock switch hopefully does it. (even if it locks it can still be bad there is another switch inside.)
Sep 18, 2008 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
61 people viewed this question
Sal De
 Brian Main
Brian Main
