Question about SonicWALL PRO 100 Firewall
DR Pro100 Firewall - SonicWALL [Trap] :: Problem Sending Log Emai
Alert Details Alert Categories Events - SNMP Traps Device LTC DR Pro100 Firewall Alert Configuration SonicWALL [Trap] :: Problem Sending Log Email Alert Timestamp 2/1/2009 6:00:21 AMOur monitoring reported the following alert. What is the severity and what does this entails?
SNMP Trap Generic Trap Type Enterprise Specific Trap Type 2 Enterprise OID 1.3.6.1.4.1.8741.1.1.2 Variable-bindings OID: 1.3.6.1.4.1.8741.1.1.1.1.1.0 Data: 604
OID: 1.3.6.1.4.1.8741.1.1.1.1.2.0 Data: Problem sending log email; check log settings
  • Mikhail Noltevich
    Mikhail Noltevich May 11, 2010
    So, are you seeing this error on your SNMP server or on your SonicWall? What kind of SNMP program are you using? Either you need to configure e-mail settings for the SNMP server or the SonicWall.
allanster
  • 60 Answers
SOURCE: our monitoring system reported the
Your firewall keeps a log of events. It periodically overwrites or starts a new log. It has a place in it's settings to put an email address so that it can send these logs to person overseeing this device. It is upset because it is trying to email the log to you but their is something wrong with the email address it is trying to send it to (could be empty, typo, etc...), find and check the setting for email address.
Posted on Feb 02, 2009
How Do I Enable or Disable Traps of a Module?
In V100R005 and later versions:
Run the snmp-agent trap enable feature-name feature-name trap-name trap-name command in the system view to enable a trap of a specified module.
Run the undo snmp-agent trap enable feature-name feature-name trap-name trap-name command in the system view to disable a trap of a specified module.
For example, to enable the hwethernetarpipconflictevent trap of the Address Resolution Protocol (ARP) module, run the following commands:
<HUAWEI> system-view [HUAWEI]<strong> snmp-agent trap enable feature-name arp trap-name hwethernetarpipconflictevent </strong> For example, to disable the hwethernetarpipconflictevent trap of the Address Resolution Protocol (ARP) module, run the following commands:
<HUAWEI><strong> system-view </strong> [HUAWEI]<strong> undo snmp-agent trap enable feature-name arp trap-name hwethernetarpipconflictevent </strong> S2300 Switch Thunder link com
Nov 10, 2016 | Computers & Internet
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
What wires goes to the ports in the back of the sonicwall 205
Hi Heather,
First off don't plug anything into the plug that says Console. Next you have 5 X ports X0- X5 If your just connecting a desktop computer you should plug the ethernet cable from your desktop to the X3 jack, and so one if you are connecting directly to the Router. If you are going to use wireless connection then you don't need to plug anything into the back of the Sonicwall 205, you'll need to log into the router and assign a password so you can log on from your remote device.
That's it.
Good Luck,
Mark
Dec 08, 2014 | SonicWALL SSL-VPN 2000 VPN Gateway - 4 x...
Get bsnl internet settings sony xperia
The high-level answer is to get the login parameters and internal IP for the Sonicwall, get the Internet parameters for your new ISP, and then log into the Sonicwall device, go to Networking-> Interfaces, and configure the WAN adapter with those settings.
Jan 25, 2014 | SonicWALL Computers & Internet
I have a sonic wall firewall and at a school site, and everytime I have inactivity on the internet, I get booted out of the internet and I am asked to re-log in with the sonic wall prompt. Is this a...
Yes. The sonicwall is set to provided authenticated Internet Access only. Once your session is up you need to log back in. You can change the timeout. Most sensible places set this to about an hour.
Aug 19, 2011 | SonicWALL 01-SSC-7436 (01SSC7436) Firewall
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
Cannot run RDP, Telnet over MPLS when sonic firewall is connected
You have to give rights to the particular systems. Means enable NAT policys in the sonicwall router.
for details go to the SonicWall Router Manual. Or else you can contact me, I will help you.
Thanks
Sriram.S
Chennai - 4
Feb 26, 2009 | SonicWALL PRO 100 Firewall
Our monitoring system reported the following event. Just want to know the severity and what does the message entails. Alert Details Alert CategoriesEvents - SNMP Traps DeviceLTC DR Pro100 Firewall Alert...
Feb 01, 2009 | SonicWALL PRO 100 Firewall
Log
Yes. You can log the traffic of your network wireless adapter, but you need to properly configure the SNMP ver1. or ver2 and you need also SNMP server, which is quite another work to do. But, the best solutions to these is to install firewall like BlackIce which logs all the traffic and the attacks.
Jan 31, 2009 | Computers & Internet
I have to restart my ASA
configure the SNMP traps and view the logs hope it will help you to solve this problem.
Jun 04, 2008 | Cisco ASA 5510 Firewall
SonicWALL PRO 100 Firewall Logo
597 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Brian Sullivan
Brian Sullivan
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
