Question about Admiral AW22 Top Load Washer
Agatates slow,wil not spin.
In the wash cycle machine will agatate real slow,if I pull on motor it will work fine,in the spine cycle if i push motor it will spin at full speed, I have checked belt its not broken, (I did find that the pump is leaking,is ther a repair kit for the pump? ) what is problem? thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On the drain pump leak, a replacement is available from here. The slow speed of the motor on both spin and wash and both working as expected if motor is mechanically moved would indicate:
  • loose connector/wiring or wiring to the motor (most likely);
  • internal problem to the motor (likely);
  • out of alignment or sticking bearing (least likely).
Pls inspect and post back results. Good luck and thank you for using FixYa.
Posted on Feb 01, 2009
    Genius:
  • 2,920 Answers
It sounds like the motor is going bad.if you have to push it to get it to spin i think you need to replace the motor
    Brigadier General:
  • 5,158 Answers
Perhaps the pump is leaking onto the belt causing it to slip
Makes banging sound during agatation cycle, tub and agator both rotate back and forth.
Lift the top cover of the unit from the front of the unit once it is free from the front locking clips, which hold the cover in place. Two things you need to inspect for damage. 1) You should see four rubber straps, which should restrict the movement during the wash and spin cycle (cost is around $4.00 each). 2) Check the shocks on the tub support rods and plastic hardware for damage.
Feb 21, 2011 | Hotpoint VWSR4160GWW Top Load Washer
AGITATOR NOT SPINNING WHEN THERE IS A LOAD IN MACHINE. IT SPINS WHEN NO LOAD IN MACHINE. (GE TOP LOADER)
Check to see if the nut on top is loose if it is tighten it up by holding the agatator with one hand then screw the cap back down, if it is still not working you will need to see if the agatator is stripped if it is you will have to buy a new agatator and you can find them at this web site. www.appliancepros.com
Nov 13, 2009 | GE WBSR3140DW Top Load Washer
Wont do the spinn cycle
use pencil or something to push the lid switch farther down if it works then replace lid switch if not...check timer
Aug 10, 2009 | Washing Machines
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
When spining it makes a gravel noise like there is dirt under the agatator and when the cycle has finished all bits of hard dirt have come out into the wash.How do l remove the agatator to clean under it?...
What type washer do you have? make? model?
Some agitator pull off, some are screwed down, some are bolted down, the bolts would be under the cap or fabric dispenser.
Jul 09, 2008 | Washing Machines
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Machine fills but does not agitate normally.
it may apear that not agatating when you lift lid
try a load in it and see if machine extracts dirt and watch drain water as it goes through cycle
the agatator is a 2 part thing and the top part rachets around as it washes pushing on the top of the load to stop washing floating
Feb 02, 2008 | GE WWSE5240G
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Admiral AW22 Top Load Washer Logo
37 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
