Question about Refrigerators
Ge side by side refrigerator problem
Last night the fridge started making strange noises, this morning saw water standing underneath freezer side?
  • 30 Answers
Sounds as if the compressor may have given out. You probably need to hire a professional to repair this unit. It is possible that the start relay is broken but without a model number I can't tell if you have a packaged start relay or if it is an easily obtainable standard overload and start relay kit.
Posted on Feb 01, 2009
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up...
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Mar 24, 2011 | GE GSS22JFMWW Side by Side Refrigerator
Water Dispenser Making Noise
Usually this means you forgot to turn the water on, once water is in the valve it should quiet down
Dec 19, 2017 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Viking side by side refrigerator noise
sounds like your fridge is not hooked up to water or water off
the sound is the water valve calling for water if no water is hooked up or supplied the valve is quite noisy
turn water on or lift icemaker arm to up lock position to turn ice maker off
Mar 04, 2017 | Viking VCSB423 Side by Side Refrigerator
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature of Refrig and Freezer too warm
Sounds like your fridge may be short of refrigerant.
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE bottem freeze- not cooling
It is not so much the freezer motor icing up but the drain trough that takes the water from defrost down to the pan.Possibly your drain trough is clogged and needs dethawing and cleaning.
Dec 05, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
