Question about Philips Magnavox MWR10D6 DVD Recorder
I have an error 25 on my dvd recorder - Philips Magnavox MWR10D6 DVD Recorder
  • 8,596 Answers
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
Good Luck!
-Tha Mp3 Doctor
Posted on Feb 15, 2009
Help quetion
Which brand of DVD-R disc did you use? What error did you get? What is your video source? Most TVs don't give video output. The tuner on the WV20V6 is an NTSC (analog) tuner. Thus you need to use a set-top box (OTA digital-to-analog converter, cable or satellite box) with the recording "channel" set to video input 1 for most channels or analog cable input to the recorder.
Verbatim DVD-R 8x, Maxell DVD-R 8X/16X and JVC DVD-R 2X have been tested and proven to work by the manufacturer. A number of DVD+R and DVD+RW or DVD-RW have been tested as well.
I've found that you have to test each batch of DVDs. Different manufacturing plants can lead to bad discs from a previously good brand.
The manual for the WV20V6 is available from Funai Corp (who manufacture the recorder for SV2000). The direct link is . See page 25 of the PDF for tested optical discs. No CD-Rs will work.
I hope this helps. Please add a comment with more information about your situation for additional support.
Jun 22, 2013 | Funai WV20V6 SV2000 DVD Recorder and VCR...
Hello! I am trying to record movies from my VCR collection to make them on the DVD format. I place the tape in the VCR ...then add a "brand new" DVD into the DVD tray (Sony DVD+R)...I then...
You are probably using a disc format which is not compatible with this model unit. Try using DVD-R instead of DVD+R. That should eliminate your error - and work fine. Give it a try - at this stage it is most likely a set of incorrect DVD formats (you can keep any unrecorded/remaining DVD+R discs for your PC (if it supports them) and use them as data storage).
* Single layer DVD-R 4.7GB/120min/4-16X discs are relatively cheap in a spindle tub (25 or 50 discs) available everywhere. *
The good news is no repair costs at this stage.
Apr 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Sony dcr dvd109 error C;13:02
i had the same problem ,but i found that when recording dont take out the dvd from cam.record only 25 min of the 30 and plug the power supply in the cam before finilizing...for the video files try a program called cd roller it worked for 1 of my 3 mini disc that i have video files on.
Apr 20, 2010 | Video Cameras
Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to select "customer access" on bottom left, then select what model, etc and there you go.
Mar 12, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
DVD Recorder
Page 25 of the manual mentions there are several satellite and copyright protected programs and other formats that the machine won't record. You may download the manual here:
I hope this clears up you issue.
Sep 28, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Mar 23, 2008 | Zenith XBR716
DVD recoder not recording
I had this problem with my R120, it first wouldn't record and eventually wouldn't play, just gave either an error message or "wrong disc.' Then, another DVD player I own did the same thing.
What worked? I opened them both up and swabbed the laser lens with alcohol and then the clean end of the cotton swab. Now both work like a charm. I figure that all the dirty rental DVDs lowly drop dust and gunk and over a few months the build-up caused failure.
Just to be safe, I also used canned air to remove from inside the unit, around the circuit board and on the lens.
I'd advise leaving the unit unplugged for a day or more to let any stored energy drain and if you're not familiar with safety procedures, take it to someone who is.
Nov 03, 2006 | Samsung DVDR120 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
1,693 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
