Question about NetGear WN121T (WN121T100NAS) Wireless Adapter
WN121T Adapter constantly loses connection. Othe wireless adapters work fine without drops. I'm using Vista, driver version is 1.0.4.3 10/26/2007. Router is TP LINK (N)
  • 24 Answers
Try swapping adapters from another of your machines, this one may be faulty. Location may also be a factor, try to locate so that antenna unobstructed from router.
Hope this helps
Posted on Feb 01, 2009
The network set up just fine, and the adapter connects perfectly to the Netgear wireless network. One laptop connects wirelessly via the XAVN2001 extender, but the other laptop (in the same room) cannot...
Try searching for drivers on the second laptop. also, try updating the firmware of all your networking equipment. those things alone might solve your problem.
Feb 28, 2011 | Computers & Internet
I have a Kingston KNE100TX network adapter and I can't find a Vista driver which works
Windows vista is the most modern innovation in computer systems. Vista has the wireless also known as wifi an improvement over the network adapter devices. Windows vista computer can teleconferece with network adapters only requires that the adapter be a modern innovation to meet the new features in vista computers. The KNE 100TX is an outdate version communication device comparted to the computer with Vista. The adapter would continue to fucntion only when an older version computer either windows millennum, 2000, 98 were used to derive networkc connectivity.
Feb 08, 2011 | Kingston KNE100TX /REFKINGSTON 10/100 NIC...
I have just bought a new computer and i am trying to install my linksys adapter to my new computer. it worked fine on the old 1, but is not working on the new 1. I am wondering what could be some problems
The WUSB54GSC adapter had been out of production for a while...the last driver update was for Windows XP in 2008 (for Version 2 devices). You should carefully examine the device to see if it is Version 1 or Version 2, as this is necessary when visiting the driver page.
If you're trying to use the adapter on a Windows 7 machine, and Windows 7 does not automatically install the driver, then you're pretty much out of luck as Linksys does not supply a Windows 7 driver for this unit. They don't list a Vista driver, either, although often XP drivers will transfer to Vista without difficulty.
So...if you're trying to install it on a Vista machine, try downloading/installing the XP driver for your device version...it MAY work. If that does not work, or if it's a Win 7 machine, time for a new adapter.
Most new computers these days (at least laptops) have wireless built-in and don't need a USB adapter. I'm assuming, therefore, that you're using this on a desktop. If so, and you need a new one, very good quality ones can be had at WalMart for around $20. Just be sure whatever you buy is compatible to your operating system. It will be printed on the packaging.
Hope that's helpful.
Jan 20, 2011 | Linksys WUSB54GSC Compact Wireless-G USB...
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
How do you connect WIndows Vista to Windows 7 through ADHOC?
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 04, 2009 | Computers & Internet
Wn121t won't connect to the router
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Aug 18, 2008 | NetGear WN121T (WN121T100NAS) Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Dec 01, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
NetGear WN121T (WN121T100NAS) Wireless Adapter Logo
205 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
