Question about Schwinn Mesa Gs Mountain Bike
I need to raise the height of my handle bars.
I want to attach a child seat. I have a Schwinn Mesa GSX. Is this possible?
  • 469 Answers
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Posted on Apr 19, 2009
How do I raise the handle bars on a Schwinn Cruiser Alloy Seven?
There should be an allen wrench fitting on the top of the handlebar stem. Loosen (counterclockwise) so that the bolt head is up at least 1/4". Then tap the allen wrench with a hammer. The stem should come loose so that you can raise it. Be careful not to go above the "Max height" mark that will be engraved on the stem.
Oct 04, 2016 | Schwinn Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
How do I get the gears to work again on my Schwinn Mesa GSX Mountain Bike?
The shift cable is likely too loose, but there are multiple items to tighten, lubricate and adjust on just the derailleurs, let alone the rest of the bike, before it's safe and ready to ride. I would suggest you get some assistance from a more knowledgeable friend, a bike co-op or a bike shop.
May 18, 2017 | Cycling
I have a 4 year ols schwinn omni 191 C5 bike, i would like to raise the handle bars? can figure how to do it, used me hex thingy to remove bolt from sterring column and its would not raise, any help?
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Jul 26, 2011 | Schwinn Cycling
I just purchased a Protocol 1 bike. I need to raise the handle bars. What is the procedure? Thank you for time. Carter McFall
Loosen up the goose neck in the center of the handle bars. There is a bolt there. Directly under that bolt you will see a large nut. Get a pair of channel locks or a crescent wrench and loosen up that nut and you should be able to push up or pull down to loosen the handle bars and change the height. Once you get them where you want them, remember to tighten up the large nut as well as the bolt on the goose neck.
Jul 06, 2011 | Schwinn Protocol 1.0 Men's Dual-Suspension...
What size seatpost fits the schwinn mesa gsd? what size seat clamP? what size front derailuer? what size bottom bracket?
As this example shows, they don't publish all of those variables...
http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=2004&Brand=Schwinn&Model=Mesa+GSD&Type=bike
Ask Schwinn.
http://www.schwinnbikes.com/contacts
1-800-626-2811
The year it was made might affect the answers. Ever seen this before - "*All prices and specifications are subject to change without notice."
Jul 06, 2011 | Schwinn Mesa GSD Men's Mountain Bike
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Trying to raise handle bars on roadmaster xtreme hype.trying losing 2 big nuts on top section of the fork. doesn't seem to do anything. tried losing the allen type bolt at the top the fork but it only...
You loosen the nut that you see where the handlebars enter the front tube on the frame. Pull up a bit after loosening and then be sure to tighten the nut back when you get it where you want it.
Jul 05, 2009 | Schwinn Mesa Gs Mountain Bike
Mutsy
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube' on the left. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Nov 15, 2007 | Mutsy 4Rider - Pink Stroller Frame
Schwinn Mesa Gs Mountain Bike Logo
1,922 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
