Question about Whirlpool LSR5132PQ Top Load Washer
Washer won't aggitate or spin.
I have a whirlpool ultimatecare top loader washer model# lsr8233eq0. The washer will not aggitate or spin. I checked the motor to transmission coupler and it seems alright. when I put it back together the washer worked fine for awhile. Then it over filled and would not do anything but fill. The level selector tube is on. How do I fix this? Is the timer switch bad? Thank you Terry
  • lorettak Apr 21, 2009
    i have a whirlpool washer it wont spin and sometimes the spin cycle cuts in and out but does not drain the water out how do i know what the problem is.
  • 686 Answers
Your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Posted on Apr 06, 2009
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Whirlpool LSR8233EQ0- The load is still wet after spin cycle
Inner tub loose or bearing or stem is bent. Check belt for oil or wear.
Oct 20, 2009 | Washing Machines
The basket is tipped forward
Most top loaders have 4 springs supporting the drum. In your case 1 spring has broken or come away from it's mount.
May 09, 2009 | Whirlpool LSR7333 Top Load Washer
Tub gets off balance during spin cycle
also,shorten front legs,lean washer forward,and reset back legs.level.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR5132PQ Top Load Washer Logo
353 people viewed this question
Dan Webster
Dan Webster
Sal De
