Question about Whirlpool AD25BBK Dehumidifier
Whirlpool dehumidifier AD25G0 -runs but no water collected
The unit turns on and cycles but humidity is not removed, no water in the pan.
  • waskelis_m Feb 22, 2009
    The dehumidifier appears to be running but it's been a weeks since any water has been collected
Illeagle
  • 525 Answers
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 41 Answers
SOURCE: Water collection
the unit is iceing the coil ck for air flow clean coil or its a more serious poblem like refrigerant or compressor capacity dan
Posted on Jul 17, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
Motor runs, but dehumidifier does not collect water
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. The fan running, may be the automatic defrost cycle, that defrost the coils, if they become frosted over. The defrost cycle, depending on the unit and how is was designed, can last any where from 15 minutes up to 45 minutes.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Whirlpool Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
No condensation. The fan blows but no water in the bucket?
Take care.
Aug 19, 2010 | Whirlpool Dehumidifiers
My whirlpool dehumidifier fan runs, but no water is being taken out of the air; cleaned the filter and still no change; dehumidifier was purchased in August 2008.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
It runs it just doesn't collect any water. Not even a drip.
Take care.
Aug 15, 2010 | Whirlpool AD25BBR Dehumidifier
Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Apr 21, 2008 | Kenmore 54501 Dehumidifier
Whirlpool AD25BBK Dehumidifier Logo
556 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
