Question about Canon PIXMA MP160 All-In-One InkJet Printer
New Canon MP610 scanner makes loud noises
New MP610 scans documents and images very good but makes noise when scanning that varies in pitch and loudness regardless of dpi setting or type of document. Varies between a loud whining to tonal annoying sound that hurts your ears.
Is this normal? I've never owned a scanner before but it doesn't seem like it should be so loud without something being wrong? Is there anyone else that owns one that is relatively quite?
  • npgamache Feb 01, 2009
    Thank-you for the information, it's very helping reading about someone elses experience, I'm going to try emailing them. I've actually have the MP610 but somehow posted the info it the MP160 section.
  • 214 Answers
I own this model too. It is very quiet. Sounds like a problem inside unit. I had a different problem with mine so I emailed them. They were very helpful & are replacing my unit. You may want to email them. Here's the email address I used. Good luck.
If this was helpful plz take the time to rate this. Thank you kindly.
Canon Support - MFP [mfp@cits.canon.com]
Posted on Feb 01, 2009
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Good Evening, I have a i420 Kodak Scanner when scanning in images it makes this high pitch screaming noise.
I highly doubt the main board is going bad. There is a huge difference between an electronic high pitched noise vs a scanner noise. Does the noise only occur while scanning or when parts are moving? If yes, then a scanner noise. If the noise is on all the time even when idle, then you have an electronic noise like an open or leaking capacitor.
On this particular model the seperation idle roller builds up with paper dust and will cause a high pitched noise. Like nails on a chalk board. Very simple fix. Open cover. Grab seperation assembly and pull toward the tray at the front of the scanner, it will pop loose then lift up. Make sure to pop it back into place good. Be forcefull. With the assembly in hand, clean, and lube idle roll. It is the first metal/plastic roll the paper touches at the tray entrance. Also clean the shafts and bushings for the rubber rolls. Reassemble and you are all set. Happens on EVERY I420 scanner I have seen.
May 10, 2011 | Kodak i1440 Pass-Through Scanner
I have a Canon Pixma MP610. Each time I scan certain 8x10 color images I don't get the whole image. Sometimes there is one fragmented piece, other times I get several fragments of varying magnifications. I...
I think this is because you have a lot of white space and canon scanners try to grab only what they think is the image you are trying to scan (rather than the whole plate). When you scan I think you can select the area you want to scan rather than just let it do it for you. It's a while since I did this so cannot be more specific.
May 29, 2010 | Canon PIXMA MP610 InkJet Printer
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
Can I save a scanned image using MP610?
Yes. PIXMA MP610 is a multifunction printer that has printer/copier/scanner capabilities.
Just install the software and drivers supplied with your printer (or download them from CANON ) and connect the printer do the computer.
The printer sofware will guide you through the operation of scanning an image and saving it to a a file in the computer.
Below is a link to CANON product support pages, from where you can dowload the software and drivers for the printer and also guides and manuals.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=2610&modelid=15604
Jul 27, 2009 | Canon PIXMA MP610 InkJet Printer
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP610 Scans blurry images and photos
I had the same problem with one of these units. I had another one that worked great so I knew it should work. I called Canon and after some questions about the problem they sent me a replacement unit which works fine.
Dec 07, 2008 | Canon MP610 Photo All-In-One Printer
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
How to get rid of a black strip (1") on the leading edge of scanned documents?
You must be using Auto contrast/brightness. Change to manual, try one or two scans changing the brightness tab moving left or right and choose desire output quality. Remember the settings for that set of documents. The brightness will vary depending upon data (foreground) and noise (background). For a different set of docs you may need to adjust the settings slightly.
S. Mohan
Oct 26, 2006 | Canon DR-6080 Path-Through Scanner
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
199 people viewed this question
old marine
old marine
