How do I disable the onboard sound in an Aspire m5621 desktop
There is no option in the bios to do so and I can't find any manuals out there for this products motherboard.
  • rubenstein01 Feb 06, 2009
    ITS AN ASPIRE AM5621-EQ9300A
  • Mr-Sticky
    Mr-Sticky May 11, 2010
    would be nice if you said what model of aspire you have.
    Problem Solver:
  • 7 Answers
There is normally an option in bios to turn off. Are you sure there is no option? Its normally under onboard controller/etc. When you go into bios try holding CTRL+F1 as for some bios's this enables an advanced menu.
If this does not apply then can you go into device manager and sounds/audio controllers? It should be listed there, generically its ac97 audio, or something like this. Right click, properties, uninstall/remove device.
I hope this helps.
Posted on Feb 09, 2009
My Msi G41 TM-P33 mainboard is cann't run probability. It run first step, but don't run if i save bios setting.
Hello download the manual here:
Please unzip the file, and adobe reader is needed to read the content.
Try to enter the bios, and load default settings.
Select the boot option for the drive.
First boot device: dvd drive.
Second the harddrive.
Save the settings you have made, and leave the bios.
Good luck
Dec 24, 2012 | Intel Motherboard
Booting problems in motherboard ms9121
Hello from here you can download a manual:
You need adobe reader to read the content.
Other files can be selected in the download box.
Look also in the bios for basic boot options.
The fault could also be a failing hard drive (bad sectors)
Good luck
Dec 18, 2012 | Soyo P4VTE (SY-P4VTE) Motherboard
M925 v7.3 motherboard not booting from cd rom
You willl need adobe reader to read content.
Enter the bios (press the delete button under post) and select the boot option for the drive.
The bios must be set to boot from cd/dvd first.
Read the manual how to do this.
And second the harddrive.
Remember to save your work when done.
Good luck
Nov 26, 2012 | Pcchips P4 Motherboard PC CHIPS M925 V7.3...
Need Some Help in USB Booting
Hello to boot for usb you have to enter the bios to change the boot settings.
From here you can download a manual:
There is also youtube:
The F12 button is also an option under restart
If the setting is on in the bios.
This will give an option what drive you want to boot from.
Good luck
Oct 29, 2012 | Gigabyte GA-8I945GZME-RH Motherboard
Gigabyte ga78lmts2p will not enter bios
Hello you can download the manual here:
You will need adobe reader to read the content.
To access the BIOS Setup program, press the <Delete> key during the POST when the power is turned on. To see more advanced BIOS Setup menu options, you can press <Ctrl> + <F1> in the main menu.
Good luck
May 04, 2012 | Gigabyte AMD 760G SB710 Chipset DDR3 1333...
Download ms7312 ver1.0 k9m-v msi motherboard
if are drivers or manual u can get it from here:
Sep 23, 2011 | MSI K9MM-V Motherboard
I was installing an ide hdd when i booted the start up said something wasn't in its place...when i shut down the bios get stuck on the bios f12 f9 del page.. is there a solution to this ??? i tried...
Hi, for a start you can download a manual from here:
Try to check the bios again in the boot options.
The first HD has to be set as master and the second as slave.
Does the bios see the HD if not it has a fault.
You can read all about that in the manual.
Hope this will help you.
Aug 20, 2011 | Gigabyte GA-8I955X Royal Motherboard
My ABIT AW8-Max motherboard is showing an error "83", the manual I got of ine does not explain much other than saying "save all data in stack back to CMOS"! I dont really know what i need to do to fix...
Error message: 83h, Save all data in stack back to CMOS. 84h. Initialize ISA PnP boot devices.
First try clearing the cmos jumper on the motherboard. You will need the manual to help guide you. If you no longer have the Abit manual for the AW8-MAX motherboard you can download it by opening the link provided below;
Click on the blue arrow to start the download.
You will also need WinZip to uncompress the zip file.
Download Winzip @ this link;
Than you'll need Adobe reader to view the manual. Download and install Adobe @
Open the manual to page 2-8. Follow the instructions to clear the cmos. (Wait 30 seconds). Reset the cmos jumper back to normal. Boot you're system and press the Delete key on you're keyboard to enter the bios. Turn to page 3-1. Once the bios/cmos has been cleared the cmos resets the bios back to default settings. You will have to change some setting depending what is connected to you're motherboard.
When finished save and exit the bios. The system will auto restart. If you receive the error massage again than you'll need to replace the cmos battery. If after replacing the battery the error message still returns the last option would be to flash the bios/cmos with the latest bios. You'll find the bios file and bios utility/firmware from the Abit link below;
Mar 02, 2010 | Abit AW8-MAX Motherboard
M925 v7.3...Bios problem...ethernet option no available
For the M925G I can find a V8.0 and v9.1b motherboard on the PC Chips web site but not a v7.3. At any rate this manual clearly shows there should be an option to enable or disable the Ethernet port on the BIOS Features Setup Page near the bottom. If the option is not there and I would be more inclined to think that the wrong firmware may have been flashed to your board. You might try downloading and flashing the BIOS update again, making sure the checksums match when the procedure is complete. By the way the link to the manual I?m referring to is here:
Jan 02, 2007 | PC Chips (M925G) Motherboard
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
