Question about Cameras
Vivitar flash user manual
I have a Vivitar DF340ZC shoe mount flash for a Canon Rebel digital camera. I have lost my user manual and need to buy a replacement. I cannot even find my unit on the Vivitar website even though these flash units are still being sold on various websites. Can you solve my problem?
  • Ivan Lea
    Ivan Lea Apr 03, 2009
    I can't get the flash to synchronize with my canon EOS400D I thought a manual might help
    Problem Solver:
  • 15 Answers
A new company has bought Vivitar from Synatx Brillion - Sakar is in the process of uploading the user manuals at this time. However they will not continue to validate any warentees that were before August 2008. Try looking here www.orphancamera.com
Posted on Feb 05, 2009
Vivitar 3500 flash
Not recommended. Older flashes have the full voltage across the hot shoe contact. If that voltage touches one of the dedicated contacts in the hot shoe it will damage the circuit of the camera. 300+ volts does major damage to 6 volt circuits!
To test the flash, measure the voltage between the hot shoe contact and the metal contact on the side of the hot shoe. If the flash is fully charged and you measure 300 volts then the flash should not be used.
Later flashes put a low voltage circuit with a transistor switch in its place to protect cameras.
Oct 13, 2013 | Canon Cameras
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
Jan 16, 2012 | Canon Rebel Cameras
My flash isn't popping up automatically or manually, someone said something about a shoe problem, but I don't know what that is. Help?
The "shoe thing" people were referring to is the camera's hot-show. This is where powered attachments (usually a flash) is mounted on the camera. The metal plate on top of the camera is the hot-shoe. It should look something like this: http://a.img-dpreview.com/reviews/CanonEOS450D/images/hotshoe.jpg
However, it is likely not an issue with the actual hot-shoe. It is most likely an issue of your camera's mechanical mechanism for releasing the flash being out of alignment. Try wiggling the "manual release" button for the flash to the left and right and see if it will catch on the mechanism. Then try pushing the button to see if the flash pops up.
You can try gently opening the flash manually with your finger, sometimes it is simply a buildup of dirt and grim blocking the mechanism and once this is cleared, it should work normally.
If you get the flash to pop up but it still will not fire, try the below method: Sometimes the camera can be confused into thinking that an external flash is attached to the body, thus making it ignore the internal flash. This can be resolved by moving the microswitch under the rails of your hot-shoe into the up position (it should be down when you see it) using a toothpick. You can access this after opening the flash up manual, as described in the previous paragraph. Here is an image showing where to find the switch: http://www.business-improvement.org/fixes/canon_350d_rebelXT_flash.htm
Thank you for choosing FixYa.com! have a great day!
Feb 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Can the Canon speedlite 430EX be the slave to the 550EX speedlite
Most any slave light will work I use a old vivitar flash with a slave module in the cord to camera outlet woks gook for a fill light. helix camera .com ritz camera. or ebay don't digital flashes a little different than strobes i played with the settings until i got the desired lightng I wanted., if your camera has a hot shoe you can get a slave to fire an external flash with it.hope i helped
Dec 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Vivitar lens
Can you provide model on the Vivitar and the model of the Rebel? The serial number provided is not sufficient to find exact info on the lens mount. If you take a picture of the lens mount and upload it, it's better.
Best info I can give is this ...
The Canon Rebel is an EF mount and will accept also EF-S type lenses. Once you have the mount type of the lens, you can then locate a mount adapter that will allow you to attach it to the Canon.
For example. If the VIVITAR lens has a T-Mount, then you can get one here. Realize though that old lenses do not benefit from new camera features, so autofocus and other things may not work.
Let me know more info if you can ...
Hope this helps, if so, rate a FixYa! ThankYa!
Nov 26, 2007 | Cameras
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Cameras Logo
555 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
