Question about Sony Playstation 3 (PS3) Console
My playstation won't turn on!
When i go to turn on the ps3 it shows the green light but then followed by an orange light? then switches itself off again... maybe one in 6 attempts it works but then after around 2 minutes it runs off again. Can anyone help me please?!
  • 3 more comments
  • paul_eadie Feb 01, 2009
    thanks for your help,
    i just found the ps3 manual, and it says something about overheating, and letting it cool down, however it has been turned off for 1 day and still the same.
  • Anonymous Feb 02, 2009
    dood i have the same problem idk what is going on im going to call support
    yeah my ps3 just wont turn on either, probably overheated, but im not sure.... anyway Thanks for the help
  • tiffaany Feb 02, 2009
    Im haveing the same problem, mines just turns on, it will stay on for about 10 to 15 mins then shuts down! Can some one please help me out too! Thanks!!!!
  • CYNTHIA5637 Feb 04, 2009
    I completely disassembled my ps3 and removed the battery as the soulution says , but it still doesn't work. the red light still comes on, then green, then it blinks back red. the light just continues to blink red.
I know what is the problem the same thing happen to me before you need to open your ps3 and look for a battery that the ps3 have inside. the battery is locate under the motherboard take out and them put it back and this is everything whem you finish try to turn on your ps3.
Posted on Feb 02, 2009
  • 36 Answers
Orange light means
It tells you the PS3 is either accessing: The HDD or the WiFi.
If the flashing light is by the SD Card Ports [on a 60 gig or 80 gig] it means the PS3 is accessing them.
however if it turns off, this might be another problem.
Send it to sony for repair.
1-800-345-7669
1-888-345-7669
http://www.us.playstation.com/Support
Posted on Feb 01, 2009
When in turn on the playstation 3,red light is on and of i try to touch the sensor to make the red light into green but within a few seconds green light turns into orange and becoming red and the red light...
This is a common occuring problem what has happend is you have the ylod better known as the yellow light of death. This means the solder on the motherboard has come loose and won't supply the needed power to keep the system running so you need to either send it in for repair which is $110. It's gone for two weeks then back just as good as new
Oct 12, 2012 | Sony Playstation 3 (PS3) Console
My playstation switched of during game play now it wont turn on whrn i hit the on switch it turn green then orange and the console shuts down
if ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3... this kind of problem u can fix by using repair guide easily...........
click here to download
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Playstation won't turn on
hello i had the same problem i was playing cod when my ps3 cut off i tried to turn it back on and got a red light then a yellow with 3 beeps then it went back to red. i bought a repair kit from this website www.ps3ylodrepair.co.uk it cost me 8.99 i paid by paypal and recived it 4 days later also when you have made payment they send you a password so you can log into there site and view the full repair guide they also send you the full guide on disk if you request it when you pay for it. i followed there guide fitted the kit and my ps3 has been going strong now for 2 months. well worth a try hope this helps
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not switch on. The green light turns orange than red
This is known as the yellow light of death (ironic i know because it blinks red). This is caused when the unit overheats causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
I turn it on the green light comes on briefly then
Sounds like it broke due to heat. You can call Sony
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Green light on ps3 but no video show's up
Turn the PS3 on from the console by pressing the power button and holding it until you hear the first beep followed by a second beep. let it go after that. This resets the video to seek an active output on the console itself
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
The ps3 switches on but dosn't bring up the title menu
my ps3 turns off when i turn it on and it has an orange light.
Aug 11, 2009 | Sony Playstation 3 (PS3) Console
No sound on tv or from the actual ps3 unit, no picture.
be sure all cords are plugged in correctly and that the tv itself works if nothing helps and its not any of the cords you may need to get it looked at.
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
The playstation stays on for 2 seconds
according to my intelligence,, it is the ps3 that is fake..
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
162 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
