My wi fi on compaq m 2000 is not working the blue light is not getting turned on
  • Anonymous Mar 24, 2009
    when i press the WI-fi switch the green light doesn't blink and the Wi-Fi also doesn't gets started..
  • 34 Answers
Try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056672&lc=en&dlc=en&cc=uk&product=433559&lang=en#N2065
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=27658&lc=en&dlc=en&cc=uk&product=433559&lang=en
Or search on the compaq/hp website for m2000
Posted on Feb 05, 2009
How to turn on wi fi on compaq cq60-615dx without using button,can you suggest me short cut,i broke the wi-fi button.....
go to the start button and pull up the menu and look under the control panel for wi-fi options
Dec 05, 2014 | Compaq Computers & Internet
Hi, i have a acrr aspire one, it was not mine and can't get it to get wi-fi or internet, am not very good at this neither, i realy need help.
First, loof for a special icon along the top row of your keyboard. One of those keys turns wi-fi on and off. You may need to hold down the "FN" key while pressing the wi-fi key. Make sure that you have selected the wi-fi "on" setting. Next, you can try going somewhere that has free wi-fi such as a Starbucks coffee bar or a restaurant. Open your internet browser (Internet Explorer has a large blue icon of the letter "e"). See if you get on the internet. If so, your wireless adapter is working OK. Now, most homes have wi-fi that is password protected. Click on the little bar graph icon in lower right corner of your screen and a list of available wi-fi networks should appear. Choose your home wi-fi and click on Connect. This will open a screen where you must enter the passwordor passphrase to gain access to the wi-fi. Good luck.
Nov 13, 2014 | Computers & Internet
Wifi will not connect
i had similar problem with my netgear. had to access setting through internet explorer. should tell you you in your manual how to access yours. I turned off security settings and was able to connect. then turned the security back on and set password on both router and wi-fi devices. its been working ever since(about 1 year now). if you don't have your manual you'll have to go to manufacturers website, might have to take your I-pad to coffee shop to do that. also not sure if you can access the settings through wi-fi, might have to have a friend with a lap top that can plug in directly.
Feb 06, 2014 | Computers & Internet
CAN I USE INTERNET THRU WIFI WITH COMPAQ ARMADA E500 ?
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Regards
Manish
Jun 13, 2010 | Compaq Armada E500 Notebook
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
I dont no how to turn the wi-fi on
When it is on the wireless light will go blue on the laptop.
See if there is a button on the laptop itself with a wireless logo and press it to switch on and off
Sep 18, 2009 | HP Compaq Presario V6000T Notebook
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
