Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Does Not Stay Frozen
I have a PSC25MGTAWW Profile Regrigerator. I have found all of the Ice melted in my automatic ice maker and has dripped down into the freezer. Sometimes all of the food is frozen and at others I have found some items at the top not frozen (like the bread and the ice has melted). It sounds like the defrost system may not be working correctly. An ideas?
  • jfdjfld Mar 23, 2009
    We have the identical problem - it occurs every week or two then goes away in less than 24 hours - just enough time to melt the ice and the food on the top rack.  The freezer is over 90% full so I don't believe that is the issue.  Any ideas would be appreciated.
    Thanks -
    KMW
    Sniper:
  • 50 Answers
One of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Posted on Feb 01, 2009
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
The ice maker makes ice and fills the ice bin but every few days the ice melts and creates a frozen ice scicle path to the lower tray and all the ice has melted and frozen again below the ice maker.
The problem with the ice melting points toward a cooling problem in the freezer. This could be caused by several different problems. Dirty condenser coils below the refrigerator could be contributing to this problem. I recommend checking and cleaning these coils if necessary.
Check the door seal on your freezer. A leak through the freezer door seal may be allowing warm air to enter the freezer and melt the ice.
Make sure that your temperature control is set properly.
If these tips do not help resolve the problem, it is likely that you have a component failure or a sealed system problem. The thermostat could be bad. You could have a condenser or evaporator fan problem. You could also have a defrost system failure that is causing your cooling problem. A weak compressor would also cause this symptom.
Jan 17, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
My GE Profile Artica ice maker is making ice, but when I open my freezer, there are icicles from the ice compartment one the food below the ice maker and dripping down the inside of the freezer. The ice...
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Jun 07, 2010 | GE Profile Arctica Stainless Steel Top...
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
516 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
