Question about Refrigerators
Why doesn't the light go on in my refrigerator?
I have replaced the bulb.....
  • morvette2000 Feb 01, 2009
    How do I check the door switch? I'm a blond.(!)
    Sniper:
  • 50 Answers
The light bulb you bought was an appliance bulb,correct? the bulb screws in like any other bulb but has to be screwed really tight because of humidity in the refrigerator so this may be one solution the second is ; does your door switch work? this could be bad. to check, turn off power gently pry out the door switch, you can use a thin screwdriver . check the wires to see if one is burnt. if you have a multi meter put setting on ohms and pressing or releasing you will find if the switch has continuity. tak the wires of the switch first making note of where they goput one lead on common and other lead on one of the other two terminals one of them will give you continuity when pressed the other when it is released.if you are not comfortable doing this call a repairman. most likely though you will find the bulb wasn't tightened enough
Posted on Feb 01, 2009
Replace lamp in Westinghouse RJ390P refrigerator
Refrigerator Repair - Replacing the Light Bulb (Frigidaire ...
? 1:39
https://www.youtube.com/watch?v=7yE0ZZBNISU
Nov 8, 2012 - Uploaded by PartSelect
Refrigerator Repair - Replacing the Light Bulb (Frigidaire Part # 5303013071) ... Kelvinator, Tappan, White ...
Refrigerator Light Bulb (part #5303013071) - How To ...
? 1:23
https://www.youtube.com/watch?v=1AQTDSn4VFw
Dec 20, 2013 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace theRefrigerator Light Bulb 5303013071 on ...
Jan 14, 2016 | Westinghouse Refrigerators
Light doesn,t come on when door opens
Hi there, this sounds like either the bulb or the switch. However your "new bulb @switch" seems to imply that you have already checked them. Can you try to get a multi tester onto the bulb mount to check if there's any current going to the bulb because if it's not the bulb or switch then it has to be the circuit somewhere. I'm sorry but I don't think I have any more suggestions apart from 'put up with no light'. Sorry I can't help any more.
Jun 18, 2015 | Refrigerators
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Were is the freezer light bulb ?
Good Afternoon Friend, that's a great question!
It appears that you would need to remove the light cover to reach the light bulb of your Frigidaire refrigerator (LFUS2613LF0). However, before doing so it is very important to unplug your refrigerator and wear gloves when replacing light bulb to avoid getting cut. Once you have removed the light cover you should be able to reach the light bulb and replace it with an equivalent bulb. Then you may replace light cover and plug in your refrigerator. Hope this helps!
Jul 28, 2014 | Frigidaire Refrigerators
Freezer light does not come on when open have to jiggle swtch
Unplug the refrigerator and turn the bulb counterclockwise to remove it if the light still does not work. Insert the bulb back in the socket and turn it clockwise to tighten it. Plug the refrigerator in and reset the controls.
If the light still doesn't work, turn the control to the "Off" position and unplug the refrigerator. Remove the bulb and purchase an appliance bulb with the correct wattage. Insert the new bulb and turn it clockwise to tighten it. Plug the refrigerator in and turn the control away from the "Off" position.
Read more on User Guide for LG LFD22860 page 26 and 27.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 03, 2011 | LG Refrigerators
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
Oct 08, 2011 | Refrigerators
In the frig part their is 2 light bulbs1 doesn.t work at all the other flickers tried replacing it does the same it flickers
the bulb that does not work replace and the light sw mabe causing the flicker and if not you have a loose wire connection . mm
Sep 02, 2010 | Whirlpool Refrigerators
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Step 4
Step 5
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
