Question about Refrigerators
I have a g.e. model numberTBX 181A..the inside light does not go on. I have replaced the bulb...what could be the problem?
  • 30 Answers
Try checking the light switch, If the switch isn't closing sometimes it will shut off from the computerized board.
Posted on Feb 01, 2009
Why is my interior light occasionally flash on and off?
Because the interior light on/off switch has developed an intermittent connection. Replace the switch.
May 24, 2016 | Liebherr Refrigerators
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
Oct 08, 2011 | Refrigerators
How to replace light bulb on side view mirror
It's not possible to replace bulb in the light it's one unit with neon bulb you have to replace compleat light for that not the jest a bulb. it's most common fault in this model most of lights not working because of wiring broken or short circuit inside the mirror housing for remove and install light housing it's need experience to do that otherwise can damaged some parts inside the mirror mechanism I would like to advice you see the experience technician for mercedes to do that. and ask him to check wiring inside the mechanism first.
Sep 03, 2010 | 2000 Mercedes-Benz S-Class
Light inside dryer does not light up.
Your bulb has burnt out. Go to appliancepartspros.com put in your model number, in schematics on left side of page select #5 tumbler, bulb is part #7 cost $5.60. easy to replace, you just have to remove lens cover and replace bulb.
Aug 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Light bulbs have been replaced but don't light
Hello Binfull,
Since you replaced both bulbs with new ones and they still won't illuminate, there is a high probability that the open door switch is not working or if you have a newer style refridgerator then in some models if the electronic brain for that model sensed the door has been open for too long, it will shut off the lamps.. Try this.. unplug the firge for a minute or two then plug it back in. Check to see if that 'power up clear' cycle got the lights to illuminate. Also, if your model has a freezer that has lights in it check to see if they go on. Hope that helps you.. Good luck...
Nov 29, 2009 | Maytag Refrigerators
Parking light bulb Toyota TAV
inside the rear compartment there is a triangular shaped panel on the left and right side near the rear door
open the read door and look between the back of the compartment beween there and the rear wheel arch.
open this panel and look inside toward the rear of the vehicle
you will see the back of the tail lights.
depending on model the reverse light is the lower one.
grip and turn the plastic housing about 90° to the left to remove.
remove the bulb by depressing the bulb and turing to the left and release.
warning: do this with a cloth or glove as the bulb may be damaged and break in your hand.
replace with simular rated bulb and reverse the dismantle procedure.
LED bulbs are also available, they are bright and give off little heat and last much longer than conventional bulbs.
NOTE: ensure that the use of LED bulbs are allowed by traffic law in your country.
Nov 14, 2009 | 2006 Toyota RAV4
Looking for a free lmv181 ac millivoltmeter service user manual
Download a service manual for the Leader LMV-181A millivoltmeter free of charge from the Elektrotanya site. You're permitted two downloads daily without registration; it's a very useful service.
LEADER LMV 181A AC MILLIVOLTMETER SM Service Manual free download...
Feb 09, 2009 | Leader Electronics - Others
Light inside microwave dos not illuminate
bulb to be replaced with same similer, if it is not available please get me touch, 9791055855, india, The bulb cost is Rs: 125.00
G.K.Mahendran
Aug 01, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
