Question about Samsung Syncmaster 192N 19" LCD Monitor
My samsung syncmaster 192n has a black screne when turned on. It was fine then one day just didn't work. Nothing out of the ordinary happened to cause this.
  • ljamieson200 Feb 01, 2009
    Thanks, I will try and find one, sansung support line was no help. They told me to go get it fixed and that was it. That sounds like a logical reason, I have no idea what exactly to look for or how to change it but I am sure I can figure that out now that i have an idea of where to look.
    Genius:
  • 2,120 Answers
Your backlight fluorescent bulb is burned out.
Easy to replace, check eBay.
Posted on Feb 01, 2009
My monitor was working fine, then this morning it appears to have no power, even though it is plugged in and nothing has changed.
Can be many different problems. check the outlet and ensure the monitor and computer are properly connected.
Sep 08, 2013 | Samsung Syncmaster 192N 19" LCD Monitor
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor: http://www.flatmonitors.com/Samsung170N.pdf
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
FFFF
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
Can't find the place to put in speakers for syncmaster 192n monitor
lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Sep 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
My Monitor samsung syncmaster flashes and like the light of the controls as someone to turn off and on
You need to open it up and inspect he caps in the power supply, look for bad caps with bulging tops or seals. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 11, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
I have an old Samsung 192N LCD computer monitor, and I have been having problems with it. There is a large black, vertical bar about the size of my thumb on the side of the monitor. I don't have a cable to...
you need to repir the power supply and replace the screen. the power supply may have had bad capacitors on it . crowned or leaking. it will be cheaper to replace the monitor with a preowned on rather than repair it
Dec 25, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
Screen went black while i was on it and i have not gotten a picture since
try this first if you disconnect the cable and you get warning on the screen that the cable is disconnected,chances are the monitor is still good,next you might want to check if its set to digital or analog,
Good luck
Aug 26, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Apr 18, 2008 | Samsung Syncmaster 192N 19" LCD Monitor
Samsung SyncMaster 192N loses picture; requires re-boot
Unfortunately, you two have two unrelated problems. CB, the monitor isn't asking you for the password, that's the computer itself going into hibernation, which shuts down the video output, hard drive, etc. You need to go into the power-save settings and either disable hibernate, or change the settings to your liking.
The other question about the screen staying on for 5 seconds... thats an inverter board problem.
Apr 25, 2007 | Samsung Syncmaster 192N 19" LCD Monitor
Samsung Syncmaster 192N 19" LCD Monitor Logo
574 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
