Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator light doesn't work
Dark refrigerator, replaced the bulb and it's still dark. Fridge works fine otherwise. I don't know what else to check and don't want to buy a new fridge just because the light bulb doesn't work.
  • 700 Answers
Then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Posted on Feb 02, 2009
Why still no inner light on fridge working, ck'd door switch - not that as lower bulb comes on
If you know how to replace a light bulp, and you did buy the correct one, it should work fine. Sometimes the contacts in the socket or lamp holder don't make contact with the lamp. Look and eventually bent one or both contacts a bit.
Before you try to look in the socket, unplug the mains. I know it will be dark, but on the end of the day you will live and if you check the contacts when the mains is connected, you could touch a contact or you could make a shortage, costing you an extra way to the circuit breaker.
If you have a multimeter, put it on Ohm, and check the "new" lamp, if it isn't defect. The Ohm meter should give a reading.
If both the old and the new lamp are not defect, cheek the wiring in the fridge.
Jul 11, 2014 | Kenmore 56612 Side by Side Refrigerator
My 19 year old kitchenaid kbrs21k refrigerator still works fine BUT when i recently crammed too much stuff onto the top shelf i must have broken the plastic light cover which fell on top of the light bulb....
Take the bulb out and check the continuity. Then you should know if there is a fuse that needs replacing. If all is well make sure your new bulb doesn't have a bad element.
Dec 03, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Frigidaire refrigerator flashing
Check if the bulb holder is not loose.
Jul 29, 2013 | Refrigerators
What is the plastic coil thing inside the refrigerator that the water filter attaches to. It look like there is dark stuff in it
has your fridge got a water dispenser? if so does it work? if not thecoil is ushally the cold water storage and if it dosent work the dark stuff could just be gunk.
Jul 15, 2012 | KitchenAid (KSRD22FKST) Side by Side...
The four refrigerator lights on my Viking VCBB363 refrigerator do not come on when the door opens. One of the 40W, cylindrical bulbs is black, and obviously burned out. Do I just need to replace it? Unless...
They are not wired in series. Replace the bulb burned out and check the door switch of unit. If that is not working neither will any of the bulbs.
Sep 12, 2017 | Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
My ight will not come on. it is not the bulb
Hi, check the door light switch, check for pitted (dark/burnt) bulb socket, remove power before proceeding.
Aug 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Subzero 650 not running
Check the light switch on the door frame, if that doesn't do the trick change the light bulb. If your refrigerator is not running and cooling and the light is out check the power, plug & circuit breaker in the power center.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
345 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
