Question about Kenmore Washing Machines
Over flowing on water discharge
Hi there when my washing machine discharges water so it can go to the spin cycle it appears that it sends to much water out of the machine at one time causing it to overflow at the drain pipe in the wall and it overflows to the ground i have checked out the drain pipe with a hose and it appears to be ok and i believe when the machine is on a lighter load with less water i believe it is not as bad it is very bad on a full load what i do is i watch it and open the lid when the pipe fills up then i allow it to discharge again ans so on please let me know if there is a fix for this problem thank you rick fowzer 209 825 8585
    Genius:
  • 1,036 Answers
This is not a fault with your machine.
The problem lies aquarely with the outlet pipe in the building plumbing. Very often there is a gradual build-up of grease in this pipe somewhere before the pipe gets larger to the main drain.
The first solution is to use a solid or liquid drain cleaner in that pipe - and leave it to work at least overnight.
Then fill a bowl with very hot water and Soda Crystals - basic washing soda.
Flush the pipe with a full bowlfull of this hot water (may need a large mouthed funnel)
Also a hosepipe from the hot tap to a pipe in the outlet will work.
Once clear - you shouldn't have anymore problems.
If you wish, you can wrap a polythene bag around the machine outlet, then force this into the wall drain pipe - to make a better seal. It's not ideal, but may help with pipes that are slow to drain.
Posted on Feb 01, 2009
    Problem Solver:
  • 3 Answers
I "pinched" the drain hose restricting water outflow using a $2.50 C clamp. I adjusted the flow to meet what the drain could handle.
Posted on May 06, 2013
TROUBLESHOOT TIPS
I don't know where you have your washing machine but can't you just put the drain hose in the tub, or toilet to see if it drains? if either of those aren't close enough to dump discharge water into from your spin cycle, you may be able to add a short piece of clear tubing at the end of the existing hose using whatever connector you need to use, then put the hose back into your drain. This way you should be able to see if the pump is working. You can usually hear/feel water being discharged out of the discharge hose but I don't know what your situation is.
Sep 02, 2014 | Kenmore 98702 Stacked Washer/Dryer
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer spins but water does not discharge. spin
Tip machine back and remove the bottom panel, 3 screws. You will then see a large tube at the front, unscrew in a counter clockwise direction, and remove. Clean pin trap lubricate o ring and replace back into recepticle
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
146 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
