Question about Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized
High speed spa pump shuts off
I just installed a new 2-speed 2hp A.O. Smith spa motor for an inground spa. The low speed works fine but is not strong enough to prime the system. When I switch to high speed the pump runs for 2 seconds then shuts down. Electrical circuit does not trip so it is wired correctly. Any ideas?
  • Rod Kidman
    Rod Kidman May 11, 2010
    when you say 'prime the system' what do you mean?
    is the heater coming on when it calls for heat?
    Sounds as if something is not wired properly but hard to determine from what you have told us.
  • Anonymous Mar 13, 2014
    the spa is on a electrical / mechanical timer ... when removed and the spa plugged directly into power to run the electric pump will not run. All power has been checked ok ...
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Posted on Apr 19, 2009
High speed will not turn off
Program again the timer. Timer disproggramed.
There is a lot of kind of timers.try to tell me what kind of timer you have.see config of the timer.
Aug 31, 2014 | Hayward 2HP Pool Pump Motor A O Smith...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
3 hp hot tub motor Sta-Rite tub has two speed low for filtering and high for jets low starts and then stops high speed works fine
make sure you make a wiring diagram or just unplug the plug from the mother board and search your area for your local pool pump repair guy with free testing. these are a high $$$ motor and not a good one to practice on, save it for a pro ! it might just be a dirty switch or need to be reset I don't charge any thing for that, and while your there ask him how to take better care of your $$$ pump ?
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
I have old spa motor with Red - low speed, Black - High speed, White - Neutral, Green - ground. New Dayton 5PXG3 motor has only L1, L2 and ground. How do you wire that?
The motor should work if you connect the black wire to L1, white wire to L2 and green wire to ground. The red wire should be cut so the conductor does not extend past the insulation and the end wrapped with electrical tape.This should be correct if the motor is a 120 VAC motor. If the motor is a 240 VAC motor then the white wire is not really neutral. It should be wrapped in both the motor wiring area with black electrical tape and the other end in the timer should also be wrapped with black tape.
If this causes a problem because you now have no low speed for the spa then the only way to get the low speed is to squire a 2 speed motor.
I hope this helps.
Sep 05, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Spa Pump Wiring
Black and Red are your two hots for high and low speed. The Green is always ground and the Blue would be neutral.
May 09, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
No low speed
Did you check the speed switch? You can move the hot wire for 'high' to the low speed wire at the motor to test motor.
Nov 06, 2009 | A O Smith Motors A O Smith 1hp 115/230v Ur...
I have a challenger 2 speed spa pump. Only the low speed seems to work. I have back-tracked all switching. The correct voltage is getting to the correct motor terminals for low and high speed operation. I...
You are correct. Appaently you have a short in the winding connection and that is not a do-it-yourslef type of repair. Unfortunately, the cost to fix something like that is high since it is labor intensive and you may want to look into a new motor since the chances of additional or near future failures is likely. If you would like a quote on a new motor, contact us thru and be sure to include the voltage you are connecting to as a 1.5 HP is available in both 115 and 230VAC.
Sep 25, 2009 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Pump speed Selector Switch Contact Probably Missing, Checkout
Feb 01, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized Logo
453 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
