Question about Tascam US-144 Sound Card
Tascam 144 sony acid pro 6 no sound from midi track
I have a tascam 144 and using it with sony acid pro 6. We hooked up everything correctly. The midi tracks are picking up or recording the notes that are playing but no sound is coming out of the speakers from my computer. We cant hear anything. We used 5 pin male din to 5 pin male din shielded midi/ din cable or audio cables. Both are the same. When I play the synthiser there is a red light that also comes on midi In on the tascam 144. Could you help us with the no sound ? I keep thinking maybe the cables are both the same instead of midi out and midi in. There both black cables that dont say anything on them to let you know if they are midi in or out. Does this matter? We got them at radio
  • 60 Answers
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Posted on Feb 03, 2009
How to connect a MIDI keyboard to computer
There are quite a few ways to do this.The simplest way is to just use the USB port on the keyboard and run that into the computer. If your keyboard has a USB, then you dont need the midi to connect to a computer. You would still use the midi however for other sound modules and items that do have a midi in port however. If you dont have a midi in then you need to get hardware that does as a computer will not have a midi in. There are basic adapters that you can get that just have a midi connector to usb adapter. There are external sound card devices that will do this like the tascam 144. There are also simple devices made my midiman such as the 2x2 midisport that allows you to connect up to 2 midi devices to a computer. The cheapest quickest method if you are just starting out is the midi to usb cable though. Places like walmart, best buy, and radio shack will generally have these. However with making digital music the cheapest is not generally ideal but will get you by in the meantime.If you ever plan on recording audio like vocals or guitar then I would recommend just getting something like the Tascam 144 MK II as it will allow you to input midi, spdif, vocals with phantom power, guitar line in, through it with 24/94 bit conversion, audio drivers, and a bit of software for simple settings configuration. This would be more of an intermediate interface. If you want some pro solutions, then I would recommend going to the pro's at a musician store and talking to them.
May 21, 2012 | Steinberg Cubase SX3
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
Bouncing a MIDI track to audio
Remember midi doesn't store notes only midi codes. There are some converters that do this.
Try this:
Oct 08, 2017 | Sony Acid Pro 6 Professional Music...
What cables for yamaha keyboard psr295 to connect with tascam 144
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Aug 01, 2008 | Tascam US-144 Sound Card
Tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Feb 26, 2008 | Tascam US-144 Sound Card
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Midi problem
My dear friend I also have the same problem (i am using an us-122) but i still have the same problem). I am searching and searching for days and nights to solve this. If you find any solution please send me an e-mail on: Thank you very much.
Dec 18, 2007 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
535 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
