Question about HTC P3300 Smartphone
The hard reset has no result
After the hard reset the phone is not starting up again. It is only coming as far as the first screen with the HTC logo and ITL / SPL / GSM / OS data and that's it.
Does anybody know a solution to get it working again?
  • 2 more comments
  • Anonymous Feb 03, 2009
    same for me
  • tvswami Feb 04, 2009
    hard reset is no use. how to do it? any suggestions
  • lohse Feb 06, 2009
    Nice try for a solution. It is precisely the matter that the mobile does not start up again as it should, after performing a hard reset!
    So the problem is not solved yet, any more suggestions?
  • tzracing Feb 23, 2009
    None of those solutions worked for me. I have tried from the bootlog but it seems only with Win Vista. My HTC 3300 also stops on HTC logo.
Hi!
Have you tried connecting it to the PC and perform a hard reset? I just did it and "got back" my HTC!Lost all the data of course, but the ROM returned to the firmware and not the original (when I first bought it, etc.).
I suggest you try with pressing the two buttons (above the windows and OK buttons) and press the stylus reset button. When you have the message whether you want to loose everything, DO NOT click on SEND, but on any other button. It might do the trick without loosing all your data..
Anyway important is to be connected with a USB cable.
Hope it works for you guys too!
levisb
Posted on Feb 20, 2009
To perform a NORMAL Hard Reset
1) TAP ON START ---> SETTINGS ---> SYSTEM
2) TAP ON THE " CLEAR STORAGE " ICON
3) ENTER 1234 & TAP " YES "
IN YOUR CASE DO HARD RESETTINGS AS MENTIONDED BELOW
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen:
3)“Press Send to restore manufacturer default, or press other keys to cancel.“
3. Press on your device.
YOUR HTC P3300 BECOME LIKE NEW ONE WHEN PURCHASED IT USE IT 1ST TIME.
NOTE : ALL ADDITIONAL PROGRAMME LOADED BY YOU AND CONTACT NOS PHOTOS VIDEO SONGS STORED ON MAIN MEMORY WILL BE VANISHED AFTER HARD RESETTINGS SO PLEASE THINK TWICE BEFORE DOING HARD RESET !
PLEASE RECHARGE HTC P3300 BEFORE PERFORMING BOTH HARD RESETS
Posted on Feb 04, 2009
How to hard reset?
From the Start Screen, press the Menu button and select Settings. Select SD and phone storage. Select Factory data reset. Select Reset phone. You will be prompted again, and select Erase everything. The device will reset and restore the device to the original factory settings.
Key stroke Method
Switch off the device. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options. Press the Volume Down button to scroll down till you highlight "Factory Reset". Press the Power button to restore your phone to factory settings and also your phone will reboot.
Note: This process may take several minutes to complete.
Aug 29, 2012 | HTC Inspire 4G Smartphone
Phone is running slow
You need to take a back up of your data and then do hard rest the phone . Below is how you do it .
Menu Path Method: From the Start Screen, press the Menu button and select Settings. Select SD & phone storage. Select Factory data reset. Select Reset phone. You will be prompted again, and select Erase everything. The device will reset and restore the device to the original factory settings.
Key stroke Method Power off the device. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options. Press the Volume Down button to scroll down till you highlight "Factory Reset". Press the Power button to restore your phone to factory settings and also your phone will restart.
Also try not to install more stuff on your internal memory
Thumps up if this has helped .
Aug 19, 2011 | HTC Inspire 4G Smartphone
My Inspire 4G won't boot or load past the "Rethink Possbile" logo. How can I fix it? It just started. Please help.
A hard reset would be in order...just remember to remove your microSD memory card to avoid it possibly being erased. Here is what you do. Power down the phone. Press the volume down and the power button at the same time and hold them until you see the HTC logo. A white screen will come up with menu options. Press volume down until you get to factory reset. Press the power button the the phone will restore to factory settings.
Aug 09, 2011 | HTC Inspire 4G Smartphone
My tmobile hd7 is stuck on the start up htc screen,how can i fix it?
It somehow need to update the phone with the same firmware,many issue regarding this problem,but give this thing a try,might be your luck day.
To start up with,
* Turn off the phone.(be sure battery is fully charge)
* simultaneously press volume up and down then press power ON.
* a message comes out,simply follow instruction,you may release the volumes now then press down volume key to proceed with the hard reset(camera button will be the enter key) .just wait the process until the phone reboot.DONE
Here's a video so you can visualize the procedure.
Aug 08, 2011 | HTC HD7 Cell Phone
My dopod 818 pro gets hanged on start up at htc innovation logo....please help
do a hard reset, beware all data will be lost and you need to calibrate screen again.
press two soft keys above call and end button press power button and insert stylus in reset hole,
phone will display some thing press green send button to restore or format.
you are done
Dec 22, 2010 | Dopod 818 Pro Smartphone
When i turn on my htc desire it gets past the htc logo screen but right after gets to the black screen with android logo on it and then gets stuck and keeps looping on that screen. please help
there must be an application creating that prob. most probably a third party software u have installed. u have to hard reset ur cell phone. consult user guide of ur cell for instructions
Aug 19, 2010 | HTC Desire Cell Phone
Htc tytn 2 problem
Try to hard reset your device. Your device will return to its factory defaults. Your device's user manual tells how to do it. Just in case you don't have it, press and hold both softkeys. Whilst keeping them pressed, briefly press the reset pin with the stylus pen. Release the keys as further instructions come up on-screen. Just follow them.
Hope your device comes back to life soon.
Cheers! Carlos
Apr 27, 2010 | HTC PPC-6800 Smartphone
My lad was messing with my htc s710 and put a new password into phone and i cant get into phone any ideas
to hard reset the htc s 710.
1) switch off the phone first,
2) again switch it on....and as soon as the green led starts blinking (indication of phone coming to life) immedietly press and hold both the soft keys at a time, and follow the instruction given on u r phone screen. :)
This should wipe the phone completely, including the password.
Oct 02, 2009 | HTC S710 Smartphone
How to hard reset the htc 710
to hard reset the htc s 710....................
Jul 09, 2008 | HTC S710 Smartphone
HTC P3300 Smartphone Logo
265 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
