Question about HP LaserJet 1022 Printer
New HP 1022n, left half of printed page blank, right half ok
New printer, new cartridge HP Laser Jet printer
  • 3 Answers
Make sure when you unpacked your printer you took out all the packing styrofoam and small cardboards out of the inside of the printer.
Posted on Feb 01, 2009
Printing Hp Laserjet 2550n
there is a clutch that stop/release the movement on the carousel,is located on the top right part of the carousel. remove and clean the STICKY CLUTCH.
Reinstall and ready to work
Mar 09, 2010 | HP LaserJet 2550n Printer
Black spots lined up on page - cleaning sheet didn't help
To tell if it's the fuser you can do a half way test, what you have to do is print a document, and open the front door of the printer to stop the print job half way through, you should see that half of the toner is fused to the paper and half is just applied to the paper, if you see the black lines on the fused side of the page its the fuser if you see it on the entire page it could be the etb or the cartridge.
possible fix:
This is a common issue with laser jet printer,
Try running cleaning modes under the service menu on the printer, run 5 back to back. if the issue is still showing, try using a different cartridge and run the cleaning mode again. If you have an old cartridge even if its close to being empty you can do an override on the printer to test the cartridge:
1.press ok
2.use the arrows and navigate to the system set up menu
3. press ok
4. print quality
5. press ok
6. override out
7.press ok and again ok to set
This could also be a build up of toner in the fuser assembly, and you may have to adjust the fuser temperatures in the embedded web server. You can print a blank word document (20 pages) and see if you still see black dots, if you do it is likely to be the fuser, set the driver and printer settings to card stock or heavy in order to heat the fuser more than the usual temp and print 30 blank pages this should resolve the issue. if this does not there could be damage to the ETB or the fuser assembly and servicing of the printer would be required.
take care,
Al
eliteprintersolutions@gmail.com
Dec 11, 2009 | HP Laserjet Cp2025n Printer
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
HP laser jet 4045TN is printing a blank page before the actual documents i am printing. In the top left corner of the 'blank' page it usually prints either *s1M or s1M. Do you have a solution for me?...
i am an expert in a different catagory,...
but i read your problem accidently and i had the same problem with my laser jet..
check the order list (in you PC screen in the right end of the START bar there is a little printer ...)click on it
and if you find a printing order of a blank page delete it...if not
then its not the same problem and am sorry i can't help any more..
Jun 08, 2009 | HP LaserJet 6p Printer
White stripe down left side of page ?
remove the toner cartridge and shake it upside down for couple of minutes vigoursly.and the check the printou.if it prints ok,but if same problem then toner needs refilling as the toner cartridge is empty.or there is powder but due to moisture its got stuck internally.
May 05, 2009 | HP LaserJet 1022 Printer
I have a HP laser jet 1022n printer.i have had it just over a year. When i print it leaves a smudge runnning down the left hand side of the page. i cannot read the firt 2cms of each line. i have replaced...
sir,
I think theres a problem with the drum of the cartidge try to replace it with a new one. and if still a problem maybe you have to replace the fuser film of the printer.
yours ,
alecz
Apr 25, 2008 | Office Equipment & Supplies
HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Feb 27, 2008 | HP LaserJet 2840 Printer
HP LaserJet 1022 Printer Logo
94 people viewed this question
Ben Johnson
