Question about Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer stops in mid cycle and then starts up again
In mid cycle the dryer stops and then after a few minutes it starts up again model lcq8858jq0
  • Anonymous Mar 22, 2014
    dryer stops mid cycle and error code 64 shows
  • Whirlpool Master
  • 4,654 Answers
Make sure of mode# make inside door and I will help you. also how old is your drier?
Posted on Feb 02, 2009
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
We have an LGR8648 gas dryer. When you start the dryer, it heats up just fine. At some point (after 15-20 minutes, it seems) the burner goes out and never comes back on. Is there a thermal sensor or...
The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
Jul 24, 2011 | Whirlpool LGR8648 Gas Dryer
Dryer keeps turning off mid cycle. Fuse is OK.
u may have blocked air flow that is tripping a resetable limit switch. if i had a model # that would help.
Jan 31, 2010 | GE Spacemaker Washer and Dryer Electric...
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
Dec 04, 2009 | Heating & Cooling
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LER4634J Electric Dryer Logo
269 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
