Question about Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated
Cannot sight in riflescope for elevation, adjustment is maxed out
Bushnell banner scope, Remington model 700. Shoots 6 inches high at 25 yards and elevation screw is maxed out.
    Habit-Forming:
  • 143 Answers
Try adjusting the knob the other way. It sounds to me like you're going backward. Screw the knob all the way the other way and then try another shot. Trust me. It's more common than you'd think.
Posted on Aug 15, 2016
    Problem Solver:
  • 7 Answers
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Posted on Feb 09, 2009
Son just bought me a Bushnell Banner Dusk&Dawn 4 Plex, Mil-dot, 3-9x50E. Just looking for an explanation on all the marking on the reticle (inside of the scope) I understand the cross hairs and how to...
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Aug 28, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
My Bushnell Banner rifle scope 3x9x40 ia at max elevation and shoots low The scope is used on a marlin 1894c underlever rifle and attached to a weaver rail how can i fix this problem
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Feb 27, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
My Weaver Classic riflescope is maxxed out for elevation
I don't think the tube holding the cross hairs will go up that high, and shimming the front base, I don't know. What you need is a new cross hair with the dots below the cross, They will raise your line of sight past the 350 zero. Or,,,,, just put the cross at the top of your target, 600 yards without the right scope is a long shot. I hope you have a heavy barrel target rifle in 308 or bigger. My M42 is unbelievable, but, It will shoot better than me all day long and I rarely go over 200 yards. I tried the 600 yard line once, didn't like it. Oh I could hit the target, but I like hitting doorknobs at 200 yards better. What are you shooting anyway? I hope your not trying to stretch out a 223 to the max.
Mar 01, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I HAVE LOST ONE OF THE CAPS OFF THE ELEVATION AJUSTMENT
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Oct 31, 2009 | Bushnell Banner 6-24x40 Mill Dot Reticle...
Bushnell Trophy scope on BLR .308 -- was fine when last used but now shoots 4 ft high at 100 yards and elevation screw is maxed out -- doesn't seem to have moved in rings and no visible sign of damage --
Rap it on its nose. Us a good screw driver and just give it a tap, not so hard to dent it but a good smack. with the handle. If this does not work remove it smack it, then remount, putting the rings is a small bit different location.
Oct 13, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
To adjust the vertical on a Bushnell Banner scope, which way do I turn the screw and how much. I am 6 inches high
The top turret should be the one you need. You should see an U or D with an arrow pointing in one direction or another. Your scope should move the point of impact 1/4 inch at 100 yards for each click. Moving the adjustment 24 clicks in the down direction should fix you up if you are shooting at 100 yards. The movement will be linear for other distances.
Sep 29, 2009 | Bushnell Banner 3-9x40 Riffle Scope, Matte...
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Bushnell banner elevation maxed out
It sounds as if your Scope rings are out of alignment or the front ring is lower than the rear ring. You may be able raise the bottom of the front ring by inserting a shim under the front ring base.
Aug 08, 2009 | Optics
Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated Logo
2,373 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
