Question about Sunpentown 1000W Port Gas Generator
Recoil Starter Looking for a recoil starter for the Sunpentown 1000W Port Gas Generator. Desperate need for family stranded in the Kentucky situation. Any help would be greatly appreciated. Thank you.
Did you find a solution for replacement? thanks
Posted on Jul 07, 2009
How to change recoil rope
How To Replace The Starter Rope On Your Recoil ...
? 4:47
www.youtube.com/watch?v=Q3NjVomUQJM
Feb 25, 2009 - Uploaded by craig1974 Me showing you how to replace your starter rope on your recoilassemblies.
Sep 11, 2015 | Honda EU6500iS Inverter Generator
Where can I get an ignition switch for the powertrain pdg6500excs generator?
PowerTrain Elite Contractor Series 6500 Watts Recoil Portable Generator with Electric Starter you are outta luck,fabricate your own parts,they are not in business anymore,here are some comments,,,,
"This generator was built in china, but Honda sued them and is no longer in buissness.
"This is by far the worst generator I have ever seen in my life. The company must not even exist anymore because I cannot seem to get the generator to stay cranked for more than a couple of seconds. I have rebuilt the carb and flushed the gas tank and changed spark plug and just checked over everything, and still does the same thing. I was hoping to get in touch with the company that makes it and I cannot find anything on them or their products. Its like they never existed. If anyone knows any information on this company and how to get in touch with them please send me an email. patricknix2@gmail.com"
"where can i get parts"Asked on Wednesday, September 24, 2008 by jj from birmingham, al 35234 about PowerTrain Elite Contractor Series 6500 Watts Recoil Portable Generator with Electric Starter
Know the answer? Answer this question
Jul 14, 2015 | Electrical Supplies
How to fix recoil starter?
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
May 11, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Gas tank leaks is rusted inside and out am looking for a replacement tank
find a honda dealer and pray its not expensive... Or find a small engine shop and see if they have some junk generators laying around and buy the best tank they have and make it work...
Dec 27, 2013 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
May 23, 2010 | Coleman Powermate Premium Plus 6250W...
Where do you get a recoil starter
1-866-393-3968 call them for a replacement
Dec 28, 2009 | Sunpentown 1000W Port Gas Generator
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
Recoil problem
Hi there .
You can try to remove the recoil starter and turn the flywheel by hand . If it turns by hand you have to replace the recoil starter if it does not turn by hand that means the piston is seized and you have to replace the piston ans probably the cylinder . To do that you need some mechanic experience .
Hope this help
Sep 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Sunpentown 1000W Port Gas Generator Logo
157 people viewed this question
Top Sunpentown Electrical Supplies Experts
John Trevino
lloyd cole
rlev_7
Level 1 Expert
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
