Question about Frigidaire ATF6000ES Front Load Washer
Washer does nothing
I bought a whirlpool frontload washer, we can't get it to fill with water, does anyone have suggestions, we have checked water pressure, hoses, is there anything else we can try?
  • 640 Answers
Ok we need to check a couple of things...take the fill hose off ,,,now put unit in a cycle and make it call for water...is the inlet vavle humming or vibrating....will your there look in vavle and see if your inlet vavle screens are clogged...does the unit have water in it,,if so it wont fill with water in it...keep me posted onthejob
Posted on Feb 02, 2009
My whirlpool frontload washer does not have enough water to wash or rinse properly
1. do you have limescale in your source water, if yes you need to clean your machine with a special product that can be found in the market.
2. pressure sensor is broken
3. inlet filter is dirty you can unscrew the inlet pipe and look for a small filter and clean it.
Mar 24, 2014 | Whirlpool Duet 4.0 cu. ft. Front Load...
Whirlpool frontload WAsher. After I run a load, the clothes come out fine. Several hours later there will be an inch of water in the tub. 10 hours more there are 5 inches of water. I have checked the...
It sounds like the water inlet solenoid valve at the rear of the washer where the hose hooks up is leaking, more than likely the cold water valve.
Jan 31, 2012 | Whirlpool Washing Machines
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
Washer fills up with water but does not spin or drain
it may have a bad lid switch you can bypass it to check
Apr 17, 2009 | Whirlpool Washing Machines
FH on whirlpool duet frontload washer
ck to be sure drain hose is at least 30 ins from floor and not fitting tight in standpipe..this will siphoning problem ...be sure all water is full on and fill screens in fill valve are cleaned..most likely suspect is flowmeter located under top on left side small round object with 2 small hoses
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
