Question about Kenmore 42800 Stainless SteelCooktop
Kenmore Elite Induction Cooktop Error Code 41
I have received an error code 41 and E's across the board on all my burners on m Kenmore Elite Induction Cooktop Model 790. Problem is I can't find anywhere what it means on the web for Kenmore or Electrolux. I have tried shutting it down at the breaker for 20 minutes and it still comes back on with error 41. Any help would be appreciated. It is stuck until we do whatever we need to do to fix it.
  • polarisonly Feb 14, 2009
    We just installed our Kenmore cooktop, and got the E's across the board and the "41" error code just like caffeinated2. We tried turning the power off and then back on but the same codes appeared.
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
YOU NEED SERVICE FOR INDUCTION OVEN AND MICROWAVEOVEN SERVICE FOR ALL BRAND JUST VIST WWW.microwaveovengkm.com,
Call : 9791055855, 8056355855, contact to : G.K.Mahendran/ Chennai/ india / Tamil nadu
Posted on Nov 05, 2011
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
What does Error code 35 on an induction cooktop mean
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
Feb 18, 2015 | Cooktops
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
Aug 27, 2012 | Electrolux 37 in. Designer Series...
I have an induction cooktop model EW36CC55GS and when I plug it, it shows an error E95, I look for a error code chart but there is none. Can someone know what is this error?
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
Aug 13, 2010 | Electrolux 37 in. Designer Series...
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Kenmore 42800 Stainless SteelCooktop Logo
1,292 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
