Furnace won't start
Pilot light is on but gas furnace won't start
    Genius:
  • 2,920 Answers
Find out if it has a thermocoupler and if so i think it will need replaced. that would sttop it from lighting
Posted on Feb 01, 2009
4 Suggested Answers
hotuna
  • 288 Answers
SOURCE: gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Posted on Dec 20, 2007
  • 10 Answers
SOURCE: pilot light on furnace wont start
Make sure your cleaning company didn't shut off the furnace at its disconnect located on or adjacent to and forgot to turn it back on. Other than that nothing they did should have effected the furnace unless they cleaned the furnace too and maybe left the blower door loose so the door switch can't connect.
Posted on May 04, 2009
koolbreezes
  • 540 Answers
SOURCE: Intertherm furnace pilot won't light
There should be a reset button in the upper chamer next to the fan motor. In the middle ,push in on the center red button to reset it, this tripps because it says I,m not gettig enough air flow due to a plugged or dirty fliter located on the front cover or door.
Posted on Dec 18, 2009
What do I need to do to lite my heater after a summer rest?
How to Light a Furnace Pilot Light Here, we'll explain the basic steps for re-lighting the pilot light of a gas furnace.
#1: Locate the Instructions Label on Your Furnace
Every furnace should have a label on it that tells you how to light a furnace. Sometimes, however, the printing may be small or the furnace area may be dark. In these cases, the label may be difficult to read. Keeping the following instructions near your furnace or in another safe spot where they can be located easily will make the task much easier.
#2: Find Pilot Light and Components
Near the bottom of your furnace is a switch that normally says "Pilot," "On" and "Off." Find this switch and turn it to the "Off" position. Wait at least five minutes. This is important because it gives the gas time to dissipate, which is necessary to avoid possibly starting a fire. While you are waiting, take note of the location of the reset button, which should be near the dial you just turned to "Off."
#3: Re-Light the Pilot Light
Once the gas has had time to dissipate, turn the knob to "Pilot." Then, hold down the "Reset" button and bring the flame of a long lighter close to the pilot light opening. This should light the furnace pilot light. Once you are sure the pilot light is on, release your pressure on the reset button.
Sometimes, seeing a job bein
Oct 28, 2017 | Heating & Cooling
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
I replaced the thermocouple and I can not get furnace to light.
turn to pilot to light pilot
hold and wait should be instructions on control
turn to on position if pilot goes out start again
Nov 02, 2015 | Heating & Cooling
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
GE furnace pilot won't ignite
Check for 24 volts at the pilot valve on the gas valve, if there is voltage, take an amp reading, if you get amperage it's trying to work, see if pilot orifice is obstructed by webs etc. very common to see this.
Oct 31, 2012 | Heating & Cooling
Furnace Pilot Light Won't Stay Lit
Here is something similar that happened to me. I went through the same steps you went through and upon closer inspection, I found a spider had made a web inside the supply line only letting a small trickle of gas through. Have you verified there is nothing blocking the line?
Oct 02, 2012 | Heating & Cooling
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
I have a Dayton 3E290 wall heater that was installed new 30 years ago. The pilot light started to extinguish a few years ago. Gradually this began to occur more frequently. I've changed the...
The pilot assembly may need cleaned out and the orifice cleaned, also the gas valve may need to be replaced, to check for proper voltage from the thermocouple you need a flame source and it takes a meter that can register DC milliamps, and should be 350 to 750 millivolts. Heat the thermocouple with the pilot or other flame source and check, if OK, gas valve is weak.
Nov 02, 2011 | Dayton Gas Furnace Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
