Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Key strokes to get desktop image to external monitor?
I've got a laptop that I augment with a Envision Monitor. Everytime I disconnect to go on a trip I get back and forget the commands to direct the visual signal to my Envision after I plug it back in.
  • 298 Answers
Press the FCTN key (lower left), then one of the top function keys. All laptop are fifferent and it depends on model. Dell is FCTN +F8, Gateway is FCTN + F7
Good Luck
Posted on Mar 26, 2009
My sahara al-096 is not displayin I dnt kno y
Try pressing the Fn key with the F3 or F12 key. One should have a blue image that looks like a monitor or screen. Those keys might alternate between a external monitor and the laptop monitor.
Jun 12, 2015 | Computers & Internet
Monitor not working when plugged into laptop
On some laptops, you need to enable the external monitor port. Look at the number keys across the top of the keyboard. There should be some legends in blue on them. These are associated with the Function (Fn) key. One of the blue legends will most likely activate/deactivate the external monitor port. Press the Fn key along with the associated number key to activate/deactivate the monitor port.
Sep 06, 2014 | Envision Computers & Internet
How do i connect extertnal monitor
15-pin dsub (monitor connection on laptop - connect monitor there.
Then, find key with 'fn' in blue - find another key with image of two monitors (should be f5 key) - hold 'fn' key while pressing the two monitor key - will activate external monitor.
Aug 26, 2014 | Compaq Computers & Internet
My laptop comes on but the monitor is blank
Your backlight is probably burnt out or the inverter needs replaced. The backlight will be a pain in the rear to do so you might want to try a new / used (working) inverter in it first. Hook your laptop up to a external desktop monitor. If you computer boots up, and you can see everything on the external display, you've got an inverter or backlight issue. Shine a flashlight on the laptop screen. You'll see a very dim image of your desktop.
Sep 09, 2012 | HP Pavilion dv4000 Notebook
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
How to block VGA port on my laptop
in most cases, you can switch between display modes by using the function keys. the keys from F1 to F12 on your keyboard should contain various symbols (sometimes in blue). one of those symbols looks like the front of a monitor (on some laptops it says "LCD/CRT"). look for the key with the monitor symbol (or the text "LCD/CRT"), press and hold the Fn-key on the bottom line of your keyboard and then press the display mode function key. then you will see if the image on your display switch from one screen to the other.
if you cannot find such a key, you can disable the external display by right-clicking your desktop and choosing properties from the drop-down menu. on the "settings"-tab you should be able to see two virtual displays. click on display 2 and then uncheck the box that says "extend my windows desktop onto this monitor".
May 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
The monitor turns on and connects to my computer then turn off but the power stays on. any ideas?
Make sure the external VGA port on your laptop is enabled. Not all laptops automatically detect a monitor connected and turn on the port. There will be a function key somewhere on the keyboard to control the port. Location varies by manufacturer and model. The usual sequence when you press the key is: laptop display on and external VGA off, laptop off and VGA on, both on.
Apr 17, 2009 | Envision 19" Widescreen Flat Panel LCD...
Trouble hooking external Viewsonic monitor to Toshiba laptop
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Jul 03, 2008 | ViewSonic VX924 19" LCD Monitor
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
