Question about Dacor ECD230 Epicure Electric Double Oven
Dacor ECD230 lower over won't heat up after cleaning
I recently cleaned both ovens and lower over will not heat up now. This is a recurring problem and has also happened after using broiler. Has anyone fixed this problem on their own?
Under the panel between the ovens there is a little square box with a reset button on it.
Posted on Feb 08, 2009
My friend pressed self clean on the oven and the oven said it turned off how do I turn the oven back on. I can't click bake but I can just click light.
The self clean cycly lasts several hours during which time you can't open the oven or turn it off. You will just have to sit and wait.
Sep 18, 2010 | Dacor ECD230 Epicure Electric Double Oven
I ran the upper oven cleaning cycle and now it doesn't heat or broil. I have tried the reset of turing onff the breaker for 30 minutes and that did not work.
CHECK THAT YOU HAVE 220 AT THE PLUG OR POWER CONNECTIONS. TURN OFF POWER AND CHECK THE CONNECTIONS TO THE ELEMENTS MAY HAVE BURNED . IF OK AND NO VOLTAGE THEN CONTROLS.
Mar 11, 2010 | Dacor ECD230 Epicure Electric Double Oven
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor Oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Aug 12, 2008 | Dacor ECD230 Epicure Electric Double Oven
My Dacor ECD230 stopped heating???
The high limit switch has tripped on this unit. Remove the vent panel behind the door and there will be a button in there behind the wires. Press this button with the circuit breaker turned off and that will rectify the problem. You still might need a servicer out to take a look at the unit though
Nov 21, 2007 | Dacor ECD230 Epicure Electric Double Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECD230 Epicure Electric Double Oven Logo
674 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
