Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko 2410w dishwasher problem
It works but will not heat water up,thus not cleaning properly.
ime sure it tripped the fuse the other day when this problem started.
is it repairable for a handy diy bloke.
thank you very much.
    Scholar:
  • 123 Answers
Hi there.....sounds like your through heater has failed..and requires relacing....can be difficult to test in situ...however if its testing ok....then u require a new programmer
regards Sir Galahad
Posted on Aug 23, 2009
DW1644 Beko integrated dishwasher fault. The machine doesn't clean very well, dried bits (like sand) on dishes and glassware cloudy. It's got sufficient salt, rinse aid etc. The filter is clean. I've...
I have same problem with mine (not BEKO) what I have discovered is, it seem to be where the water hasn't run off properly before drying, so I make sure I don't put anything in flat where water can collect. It's not always possible to put things in that are not flat, but try that
Dec 14, 2014 | Beko Dishwashers
The dishwasher is not cleaning properly only cold water goin through no hot
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 27, 2011 | Beko 24 in. D3421F Free-standing...
When switched on trips main fuse. have checked fuse in plug, filters etc are clean and it is not the socket.
Sounds like there is a short in the electrical circuitry of the dishwasher -- could be the motor.
Probably best bet is to have it serviced by a tech.
Charlie
Feb 05, 2011 | Beko 24 in. D3731F Free-standing...
Dishwasher is not cleaning properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Beko 24 in. D3421F Free-standing...
The dishes are not cleaned properly come out with a scum over them.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Beko 24 in. D3421F Free-standing...
Beko dishwasher DE3761 FS?, my dishwasher is not heating the water, not sure what the problem is, any suggestions?
heatman101
Sep 06, 2010 | Beko 24 in. D3731F Free-standing...
I have a Bosch she44c dishwasher that I used just this morning. This afternoon I went to turn it on and a fuse in the panel box tripped. Is there something in the dishwasher that could go bad that...
In some cases, the heat element lining wears out and the element shorts out to the chasis of the dishwahser, thus tripping your fuse.
In other cases, the dishwaser leaks water, and shorts out an electrical component.
It is best to get a repairer to check this out for you.
Regards
Ash
Nov 15, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Beko dishwasher model number DWD 4310 has stopped working and now trips the electricity when you turn it on.
Dishwashers are appliances that work in the kitchen to clean dishes. It has rules to govern its use and when those rules are broken, the dishwasher will fail to work. The General Electric dishwasher is a great addition to kitchen appliancesmag-glass_10x10.gif and also has a set of maintenance rules to ensure proper functioning. If for some reason the machine decides to malfunction, there are a few troubleshooting ideas to look into.
  1. Eliminate abnormal odors in your General Electric dishwashermag-glass_10x10.gif by removing any food particles found on the bottom of the machine. Locate any plastic, paper or other debris blocking the pump inlet and remove. Unblock the spray arm jets with a paper clip.
  2. Step 2 Do not overload the dishes, as this can cause poor drying. See that the dishes are not touching each other. Make sure the water temperature is between 120 and 140 degrees Fahrenheit for best drying performance.
  3. Step 3 Check under the sink to locate the water valve found on the water line. If your dishwasher is not filling up with water, make sure the valve is open. Turn the valve all the way to the left.
  4. Step 4 Make sure the water pressure isn't too low if the dishwasher isn't filling up completely. Water pressure must be 20 to 120 psi. Make sure that the inlet water hose connected to the dishwasher is not kinked. Remove the toe-kick plate on the front of the bottom of the dishwasher to check the hose.
  5. Step 5 Notice whether or not the dishwasher drains while filling, as this is a sign of either an air gap in the drain hose, or the loop from the floor to prevent backflow of water isn't 32" high. If either problem is located, fix it. Check the water level when the fill cycle has completed. The level should be just under the heating element. If it is not, you will know the water is draining while filling.
Nov 15, 2009 | Dishwashers
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3421F Free-standing Dishwasher Logo
356 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
