Wireless connection will not let me surf the net.
Works fine with hard line. Detects wireless connection but cannot go past google search page. Have tried everything. Helppppppppp.
  • 24 Answers
Sorry this is going to be a long answer, would be easier in a real time talk, please go one by one on my suggestions to pinpoint the problem and thank you for your patience in advance :)
Start your internet explorer/firefox, go to google main page, type something into google that you search for and click search. The reason for this is: the main page can load from an offline cache file, seeing the main google page does not mean you are really connected to it. Only if it finds results on a search.
If giving in a search word and clicking search results with no page is displayed you are either offline in your browser settings, not connected to the internet or you have browser problems. So let us check which one. :)
The browser is easiest to check, click your file menu, and down at the bottom where it says work offline. If there is a little check, untick it. Since you say however, that when you connect with cable it works I will assume that the work offline is not checked. So I will guess for the first option, that you have a network issue, so I carry on with this option.
To try to troubleshoot this, click on your start menu, select the option RUN, type into the open field: cmd
Then click ok.
It will open a black dos window. In the window, please type (after all the text that is written in it):
ipconfig
Then hit enter. This will provide you with some information about your connections. Search for the line telling you the IP address your computer is currently using. Based on what the IP is there are the following options to go:
1) If your IP address starts with 169.*.*.*, then your computer seems to be ok, your network card etc works but you did not get an ip from your wireless router though are able to connect to it. Please shut down your computer, go to the router/modem, pull out the power cable from everything and count to ten. Then plug back in the power cable, wait till all lights on the router/modem go green and start up your computer again, and see if the problem is resolved. If not resolved, check for IP again (see above, with the cmd, ipconfig). If still starts with 169, contact your internet provider and complain that you have problems accessing your router wirelessly and you receive no IP address. They are responsible for your router and they can diagnose it remotely through the connection they have to it. This way you find out fast if it is a router problem. If it is your own router, please provide router brand, type, etc some sort of number so I can look up potential problems with it:)
2) If your IP address starts with 192.168.*.* that is half ways good news, because it means you did receive an IP from the router, so at least to the router you connected. That means again card is ok, your wireless connection to router is ok, you can not browse though so let us see if there is data transfer going through, Go to start menu, run, type in again: cmd
Hit ok.
In the black window now type:
ping google.com
Now hit enter. If it says that it can not resolve the name, then you seem to not even be able to resolve hostnames. Again call your internet provider, that while you are successfully connected to your router wirelessly, there is no data transfer through it. Please do make sure you tell them the IP address and that it works with cable. If ping google does give you a line saying it can ping it, then look underneath it for how many packages are sent out and how many arrived (ping statistics). If four sent and none arrived, again it is an issue with data transfer, try turning off the router and back on, try again, and if it does not work call the internet provider.
If ping statistics says four packets sent out and four arrived :
Pinging google.com [209.85.171.100] with 32 bytes of data:
Reply from 209.85.171.100: bytes=32 time=201ms TTL=236
Reply from 209.85.171.100: bytes=32 time=196ms TTL=236
Reply from 209.85.171.100: bytes=32 time=194ms TTL=236
Ping statistics for 209.85.171.100:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
This means you can ping google, so definetly you are on the net, then back to the issue of your browser being unable to go out. Then please get back to me we WILL solve that, but I need to ask you questions then.
3) If your IP address is NOTHING or 0.0.0.0 then either your card is disabled or dhcp client is not running on your computer. You can check this by clicking start menu, control panel, system, hardware, device manager -- go down till you see the icon for network adapters, open the option, look for your wireless card and see if it has a red cross on it or an exclamation mark. If yes, right click on it, go to properties and at the bottom choose: ENABLE.
If it has no red cross/exclamation mark, then check for the dhcp client service.
To do that you have to click on start menu, control panel, administrative tools, services, and in the list search for DHCP client. If you found it, select it and right click, then choose RESTART or START if it is not running. Once it runs, try reconnecting to the wireless and check for your IP in the black window again, if it now changes to something.
4) If your IP address is none of the above but some sort of number for sure *.*.*.* that means you are on the net, you have internet IP, and yet you can not browse. Try the ping google test, and based on the results if you DO get four sent, four received, get back to me, if four sent none received, reboot router and try again and call Internet provider if still not works.
Please get back to me about which of the above happened or if this solved your problem. If none of the above solved, please provide information what your computer said at which step and we will go on on that lead. Sorry for the long answer again, but network problems can have multiple reasons:)
If the solutions did help please rate :) and let me know :D
Posted on Feb 08, 2009
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
I have a 7" Mini Ez book Net book and it will not
The only thing I can thing of is the DNS setting for your wireless connection is not setup correctly.
Make sure your wireless connection is set to Obtain DNS server address sutomatically.
The setting is located in the wireless connection's properties, Internet Protocol(TCP/IT) Properties.
or
Perform the following and compare the DNS settings for both wired and wireless connections.
Go to command prompt and type the following.
ipconfig /all
Dec 13, 2010 | Computers & Internet
My dell laptop tends to be very slow in surfing the net and rebooting. is there any way to make it surf the net faster
There Certainly is!
If its running XP then press the windows flag key + pause/break key at the same time. Then when the next window loads up, click on the Advanced tab. Then click on the Performance tab. Select the "Adjust for best Performance" check box and click apply, then close that window. Then go to www.google.com, click on "more" at the top of the page. Then click "even more" on the bottom of the drop down menu. When the next page loads up, click on Google Chrome. Follow the Instructions to Install Google Chrome and then Restart your PC.
Hopefully these things will help you out alot. I've found these little tips to be very useful in my line of work. Sam
Oct 21, 2010 | Computers & Internet
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Cannot access the 'net through the wireless router.
u need to configure your router. insert your broadband cable into wan port and then can connect ur 2 laptops through lan
Oct 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Web Page access
access the router directly (192.168.0.1 in the browser address) and see if the site is on the router firewall restricted list
Sep 02, 2008 | Linksys Wireless-G WRT54G Router
My computer uses firefox to surf the net it has gone to safe mode for some reason? has my ps3 the problem? wireless connection is fine. But computer can not go line?
hmmm..open control panel, and see what's up with network connections..should be enabled..may need to re install them
Mar 28, 2008 | Computers & Internet
Wireless Problem
Hi, it may be that you need to set/unset/reset your proxy settings and/or internet gateway. With either firefox or ie, it is normally in tools/option/connection. Please let me know if this works out for you or you need further assistance. Regards.
Apr 09, 2007 | GigaFast Ethernet (WF728-AEX) 802.11g/b...
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
