Question about Dell 926 All-In-One InkJet Printer
My dell 926 photo printer is plugged in but when I press the power button it will not turn on
    Sergeant:
    Champion:
  • 275 Answers
Change the power cord and if that doesnt help try a different wall outlet ... if that doesnt than hardware issue contact dell 18006249896
Posted on Feb 01, 2009
My 926 Dell Printer dos not turn on. The On light is off.
Make sure it is plugged in real good. It may have been dislodged somehow or not plugged in all the way. this can happen without us knowing it. :-)
Oct 18, 2014 | Dell FH214 926 PHOTO ALL-IN-ONE PRINTER
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
How do I reset my printer's setting? (Dell Photo 926 printer)
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
Cycle the power button according to the manual
If you mean the printer uninstall the printer driver, reboot and reinstall it.
Jan 27, 2010 | Dell 962 Photo All-In-One InkJet Printer
My dell printer 926 is not in englishand i cant read the display to try to change it. please help
To select the language on the Dell Photo All-In-One 926 printer, follow these steps:
  • Completely power down the printer, wait 15 seconds, then power it back on.
  • Press the Right Arrow button three times.
  • Press the Select Button.
  • Press the Right Arrow button four times.
  • Press the Select button.
  • Use the Left/Right Arrows to display the language you prefer.
  • Press the Back button to get back to the main menu.
have a great day :)
Sep 28, 2009 | Dell 922 All-In-One InkJet Printer
MY COMPUTER DOESNT RECOGNIZES THE PRINTER DELL PHOTO 926 IT HAS NEW INK
Power off the printer and disconnect the USB (Parallel ?) cable from the printer to the PC. Reconnect the cable. Restart your PC.
If that doesn't work ... go to Start - Printers and Faxes and delete the Dell Photo 926 icon. Then, power off the printer and disconnect the cable from the PC. Power on the PC and log in. Reconnect the cable and see if the printer is found. If so, install the Photo 926 printer driver. If the printer is not found, you have a printer cable or printer hardware problem. Good luck.
Jun 11, 2009 | Dell 926 All-In-One InkJet Printer
Won't copy, error message 2200 pops up and says to check manual. Manual doesn't reference that error message.
Try this - turn off the printer.
Remove the power supply.
Press the power button for 15 seconds.
Then plug it back in.
That should've cleared the printer!
Apr 17, 2009 | Dell 962 Photo All-In-One InkJet Printer
2200 error on dell 962 all in one printer came on lighted screen. then i powered the printer off and it will not work at all. unlighted screen says power down error
1. Uninstall, and re-install the printer.
Else....
2. Error 2200 is a Scan Carrier Stall error... Maybe the scan carrier stalled during a scan job? Turn off the printer, wait a few seconds, and then turn on the printer.
else
3. If no result....Try this... turn off the printer then remove the power supply and press the power button for 15 seconds (it should clear info out of the printer). Then plug the power back in and press the power button.
Thanks for using FixYa - a FixYa rating is appreciated!!
Re-Post if additional help is required.
Jan 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Printer Dell Photo All-in-One Printer 926 language
Here's an effective way to change the language on the 926 printer *turn on the printer *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key four (4) times *press the check button *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key until you find "English" *press the check button let me know if it works thanks!
May 25, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
453 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
