Question about Dryers
I push the start button nothing happens. Motor has been replaced within past year. Has worked great up untill now. Whirlpool Model # le6800xtwo.
  • 547 Answers
Wireing to button
Posted on Feb 11, 2009
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet won't start
Open the door and look at the latch on the right side of the opening. Just above the hole the door latch fits into is a small switch. It should be sticking out about a quarter of an inch. You should be able to push it in and out easily. It is very common for these to break. If it is broken, the door latch assy will have to be replaced. About $65 for the part. You may be able to break a round toothpick or something else about that size to use as an actuator until you can get it repaired. Just stick it into the broken switch with about quarter inch sticking out. Then carefully close door. Post back to let me know if this helps or not.
Oct 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
