Question about Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder
I have access to a century mig model 117-3-, 90 amp, 120 volt. the wire feed works and it welds, but it isn't getting 12 volt power to the feed. it might be the circuit board. i know the feed works because he supplied a different power source and a riostate, but of course it made it continuous use. do you think it is fixable?
  • Ron Jones
    Ron Jones May 11, 2010
    if it works and it welds, whats with the 12volt power ??
  • 225 Answers
Yes its fixable,check the main contactor for proper voltage first,power boards are high dollar,so check the price of new one then decide if you want to put that type of money in the unit.
Posted on Aug 02, 2009
Suggested setting for rossi mt 200 welder
read you hand book on the settings but it all depends on material thickness being welded
higher volts = higher amps will require faster feed speeds = thicker materials
sheet metal thickness (.040"-1mm) will require very low volts -up to 20 v with a slower feed speed
remember the unit will have a very short duty cycle and that means that you cannot start a weld and keep it going for many minutes especially at high amps
it works like this ,if it is a 20% duty cycle ( on the plate of the machine then for every 20 seconds of power ( high amps) the machine has to rest for 80 seconds
if you are welding panel metal the ( very low amps) then you can weld for longer periods but the rest period has to be 4 times the weld period
Jul 04, 2015 | Welding Tools
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
Welding will not hold
turn your heat wire speed up hope for the best too small of a machine
Oct 13, 2012 | Lincoln Electric Welding Tools
Wire feed speed problem
Check the speed control board's voltage from the fan. If you are below 20 volts, 1- oil the cooling fan bushings to see if that helps. Otherwise adding in a discrete 24 volt 1 ro 1.5 Amp "control" transformer and a 2 ohm 50 Watt resistor in place of the fan's 24 volt tap (it rarely gets to 24 volts) should bring your speed up.
This does assume the board is fully functional.
Dec 27, 2011 | Welding Tools
Wire feed
first the handler 120 is 110volt,the handler 220 is 220 volt.the rubber wheel is for welding aluminum.
Feb 09, 2010 | Welding Tools
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
Does anyone know where I can find a how to manual for a wire feed welder? The only info I have is Pow R Mate 90 amp 120 volt model number 117021. I think they were made by century welders.
There a hundreds of books published on the subject, if you live in the USA contact Hobart, lincoln, Esab, all publish books and manuals.
Nov 09, 2009 | Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder Logo
405 people viewed this question
Top Lincoln Welding Tools Experts
Robert Monigold
Robert Monigold
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
